4L60e 5.3 swap
Old Jul 19, 2019 | 06:40 PM
Fukucachme's Avatar
Default 4L60e 5.3 swap
I have a 2003 gmc envoy 4.2 the Tran is out I bought another 4L60e to put in it and found out later it was from a 2002 k1500 5.3 so I swapped the bell housing and tail and put it in now I’ve got nothing it wont go into any gear is this not a possible swap or what am I missing?
Old Jul 19, 2019 | 07:22 PM
vorteciroc's Avatar
I caught you... So **** me???
You are not getting any help with that attitude LMAO!
Old Jul 19, 2019 | 08:42 PM
Fukucachme's Avatar
It not my actual account my brother made it so sorry if it offended u
Old Jul 20, 2019 | 06:48 AM
Jays_SSZ28's Avatar
Why not use your actual account?
Old Jul 20, 2019 | 07:57 PM
brandon6.0's Avatar
It should have worked with the swapped bell housing. The truck tail housing should have matched. No need to change tht over. I know the 4.2 has starter in a diff location so u do need a ls style bell. Same trans internals tho.
U said from a k1500 truck? Sure tht isnt a 4x4 trans?
Old Jul 20, 2019 | 09:53 PM
bbond105's Avatar
Op didn't you post this same problem under the user name Wrenchn? Not Cool!!
Old Jul 22, 2019 | 07:19 AM
MaroonMonsterLS1's Avatar
it's not working because you broke the pump during install...or when you bought your $50 junkyard/craigslist trans...it was already broken
Pull a cooler line and start the truck...if it pumps fluid...then the junkyard/craigslist trans is junk
If it doesn't pump fluid...you don't know how to install a transmission and broke the pump. congrats
Old Jul 22, 2019 | 07:56 AM
grasshopper645's Avatar
Lol what a savage
