TCC slipping while locked at 100%
Any codes? You should get p1870 if the computer is commanding lockup but its slipping
What kind of truck is it?
I have a '92 ext cab long bed 454 dually and it weighs 5800 pounds, not the place for a 60, 65, 70e. But thats just my opinion and I'm a ******* retard so **** me.
Maybe the same applies for self hate?
After the system warms up, you loose lockup, even when commanding it with a scanner.
You said you did pwm delete, is that just through programming, or did you coil-bind the tcc regulator valve? I would first be looking at that valve to see if its leaking, as i believe that could cause your symptoms. Since your not using pwm you should install that fitzall valve or just use a longer spring to coil-bind the regulator valve and see if that alters the symptoms.
If thats not the issue, i'd check the apply valve has correct travel and the apply solenoid - does it hold pressure when commanded with a scanner?
If I command lockup via HPtuners shouldnt it be bypassing the valvebody anyway and just using the TCC enable solenoid(not pwm apply solenoid) to force it into lockup? I pulled the inspection plate and the front of the converter is not discolored, so maybe it isnt damaged, but then again I try my hardest to drive it without making it slip as it raises temps making it a vicious cycle. I dont think it is my tune at this point, and maybe just tranny issues.
To the question about a TB stall in a heavy Denali, yes it smaller but the lockup clutch is about the same size and it woven carbon. Im not drag racing it as many do with the same converter and Im not locking it @ WoT. We are talking about pulling small grade hills in Georgia and it slipping under light throttle. People do pull trailers loaded down much heavier than my Denali in trailblazers Im sure, and the guy at Transmission Crafters didnt say there was anything wrong with my application..I was honest with him about the Vehicle, and mods done to it.
If you dropped a checkball in it and still have no lockup, maybe its your front stator bushing. Does the apply valve stroke when you push it with a pick?
The only lock up issues Ive experienced was in my current trans am. It got so bad that on the highway I could manipulate the throttle to make it pull but then once power came on it would slip, or if I just put my foot down it would rev.
I had the trans out to install a yank ss3600 but it turned out to be a converter for a corvette. I bought it used and cheap. So not wanting to dump $900 into a converter for a bad trans I got a converter from advance auto for ~$125 to throw in there to test. Problems were solved after that. Thats the GM55 converter in my sig, Ive made about 6 1/4 mile passes and quite a few random runs on the street and I thought I needed a new transmission more than a new converter.
So for diagnostic purposes you could go get a new converter from advance auto, which will likely fail but buy you some time. or if you have the money buy a triple disc lock up converter which should help with the weight of your vehicle. My understanding is triple disc converters have stronger lock up abilitys.
Im going to test it out today and hope that it doens't slip once hot, I had to leave town as soon as I had fixed the band problem which was my fault. Im betting it was the front stator bushing the whole time, I just dont know what caused that wear...and it explains why it was fine for 4k miles after rebuild. It was my first full rebuild nad I could have overlooked something. Anything known to cause that bushing to wear prematurely?
But over the years we have seen some strange ones, Bit of material partially blocking the feed in the orifice cup plug in pump that feeds the TCC SOLENOID, Leaking pump halves not true, We have even run into pump that were not machined deep enough to allow the sonnax valve to travel far enough to vent the release oil,
Even had one the opposite it was able to travel to far grabbed the Teflon ring and got stuck in lockup.
Overall the most common issue we see with lockup outside of bad solenoids however are pump related leaks.
Of course when you do mostly all 4L60E trans several a day and test them on Dyno you get to see all the really strange things regular trans shops would probably never run into.
The stator bushing may and hopefully will be you issue and all fixed , However if not I would seriously look to replace the pump.
One thing of note the best way to check for leaks is vacuum testing, However very shiny areas on the pump face and body can also be good indicators.
