4L60E vs TH400
Old Jan 11, 2020 | 03:13 AM
Impala1965's Avatar
Default 4L60E vs TH400
Hi,
what gearbox would be the best choice for an lm7 with summit stage 3 truck cam and 243 heads? Its going in to an impala 65. What do I need to do to get the th400 on there? This adapter ring and nothing more? Thanks.
BTW, do I need a high stall converter? Im not gonna race it.
Old Jan 11, 2020 | 06:09 AM
Tuskyz28's Avatar
Find a 4L80E. Basically a tough turbo 400 with that added gear.
Old Jan 11, 2020 | 07:12 AM
Impala1965's Avatar
Wont a 4l60e do the trick if I dont rev it to damn much?
Old Jan 11, 2020 | 08:21 AM
B52bombardier1's Avatar
Your post is unclear. Do you want to keep the 4L60E or put a TH400 in? You will need to edit the operating system to remove the 4L60E from the OS to prevent a phantom trouble code and Check Engine Light if you go with the TH400. No need for a high stall torque converter because it will be annoying in street driving and might contribute to transmission overheating.
Mostly street or highway driving? I have 2.73 gears in my 70 El Camino and I stick with a manually shifted D3 gear around town to keep the RPM's up a little and not load down the engine. I only do OD in my 4L60E on the interstate highway.
Rick
Old Jan 11, 2020 | 08:26 AM
Kfxguy's Avatar
I Shift mine at 7200 and my other car at 7800. work just fine. Put in drive and it shifts at whatever rpm i set it. mine is built tho.
Old Jan 11, 2020 | 08:28 AM
Impala1965's Avatar
Rick
I havent bought a transmission yet. Mostly street driving. Is th400 a stronger transmission than the 4l60e?
Old Jan 11, 2020 | 08:42 AM
Tuskyz28's Avatar
4L60E tranmistrans go out all the time especially in heavier vehicles. The guys that make them last have lots of money in those tranmissions and they are in lightweight cars. And yes a Turbo 400 is stronger than a 4L60E.
Old Jan 11, 2020 | 08:46 AM
Impala1965's Avatar
I’ll go with the 400 then, thanks! What adapters do I need to make it fit? Just that center adapter ring?
Old Jan 11, 2020 | 10:44 AM
Tuskyz28's Avatar
Main thing is the flexplate i believe. They cost around 140 bucks or so.... trying to help you out but im a T56 guy.
Old Jan 11, 2020 | 03:27 PM
Impala1965's Avatar
Yeah, Id rather have a t56 but they are too expensive. Got a rebuilt th400 for 300 bucks. Just missing the converter and yoke.
Old Jan 11, 2020 | 06:58 PM
98CayenneT/A's Avatar
What rear end gear ?
A 4l60e will suit you more than fine.
Old Jan 11, 2020 | 07:30 PM
Launch's Avatar
Just use a 98-02 fbody ls1 flexplate and the center round adapter ring to extend the crank pilot hole. That way you won't mess things up because the truck engines had odd ball flexplates.
With that setup your th400 with sbc/bbc converter will bolt straight up. Typically you just need to run a 1/8" washer between the flex plate and the converter lugs when you bolt down the converter , to get the perfect spacing between the front pump in the trans and the crank pilot.
TH400 all the way.
4l60e are good when they work but if you drive the car hard often and especially WOT into 3rd gear, and/or top gear they do not last. With a basic rebuilt TH400 with BW clutches and a good full manual valve body and keeping trans temps under 180 it'll live a long time.
Old Jan 11, 2020 | 07:40 PM
vorteciroc's Avatar
Dang! I really do love-um me dem Tran-Mistrans!!!
Dey got-sta go out... how else naw yall gonna miss some a Tran-Mistrans!
Ya cants be missin' nuttin' if dey aint gonne out yet! Dang!
Old Jan 11, 2020 | 07:43 PM
Notcammin's Avatar
Originally Posted by Launch
Just use a 98-02 fbody ls1 flexplate and the center round adapter ring just to extend the crank pilot hole. That way you won't mess things up because the truck engines had odd ball flexplates.
TH400 all the way.
Sounds like somebody likes to party. **** I might even consider selling my rebuilt 4l60 and buy a turbo400. Not going to daily the car anyways.
Old Jan 11, 2020 | 07:52 PM
Jays_SSZ28's Avatar
That's why there are hundreds of thousands of 4L60E's in TRUCKS AND VANS, FROM THE FACTORY.
i WORK WITH A GUY THAT HAS A 2004 silverado with a 4.8, 4L60E with 380,000 miles on it. He bought it brand new and uses it to tow a camper trailer through the mountains. Never been rebuilt and runs great still.
Old Jan 11, 2020 | 07:54 PM
Jays_SSZ28's Avatar
Damn, that was quick. TH400 it is. Close the thread.
Old Jan 11, 2020 | 07:55 PM
vorteciroc's Avatar
That is because the GUY you work with has a Transmission.
NOT a Tran-Mistrans.
Old Jan 11, 2020 | 08:48 PM
Jays_SSZ28's Avatar
Oh ****. I missed that.
He is be betta wit da foehunny tran-mistran. Ma boy pokie running dat.
Old Jan 12, 2020 | 06:05 AM
Impala1965's Avatar
TH400 all the way.
I need the dished flexplate, right?
Old Jan 12, 2020 | 06:54 AM
Launch's Avatar
Yes. The early ls1 4th gen flexplates have the correct holes already drilled for the sbc/bbc converter lug pattern. The later flexplates and some of the sfi plates for our cars like the B&M one for example, do not. You have to drill them yourself. If you are not high HP, just grab one of these.. I have done over 50k miles at 540fwhp with this style flexplate behind a th400 in the past. This style below are also stronger than the later style (which rather than round holes the later ones have bigger oblong holes cut out in them)
https://www.ebay.com/itm/98-02-LS1-V...sAAOSwO0VeEL9e
