4l60e servo choice
I already have a new Corvette servo for my box but should I use this. I heard they can make shifts a little harsh. No clue what brand it is. what you guys think.
I'm still planning on using my new Borg Warner hi energy not the wide band I found in the case
You have their 2nd servo and their 4th servo.
Both of the servos are the largest (most aggressive) piston models produced for the 4L60E
The Sonnax 2nd and 4th servos are slightly less aggressive and much more popular over the Superior servos.
Keeping separator plate orifices small here can help tone down a large servo if needed.
Most people are happy with the Corvette servo unless they are a person looking for extra firm gear changes or have a really loose torque converter and need a larger servo piston for a better apply ratio.
But for single piston designs, superior is largest.
Corvette servo with wide band and new Reverse Input drum has served me well at builds over 600hp
At this point, I'm not going to mess with a recipe that works until it doesn't anymore
band .098
1-2 .078
2-3 .118
3-4 .118
Also when I installed HD2 kit I put no spacer with accumulator piston and everything has been carried out as per kits instructions.
No clue what brand the wide band I found in the box is. Friction material is dark maybe even black but no markings on in to indicate a brand
I unfortunately have to run a standard converter modified to have a 2200rpm stall but only until I get my 9" dominator 3800 rpm stall rebuilt and installed again
I've already made the separator plate holes those sizes so not sure I can shrink the band hole back down that much and I thought keeping the 1-2 hole on the smaller side was recommended.
With the install of HD2 kit, .500 boost valve and Corvette servo the shifts are definitely gonna be firmer then I've had.
I did use the white spring if memory serves but that's what the instructions said to use if I had a Corvette servo. I'll definitely look into which accumulator housing I have and adjust accordingly to your instructions Dana. Thanks mate all the advice helps.
I didnt do anything to the 3-2 feed hole unless it was in the transgo instructions to drill out. I would definitely be interested in firmer downshifts to help slow the car down (commodore brakes are a little mediocre) any instructions on modifying the valve body or seperator plate I'll take ✌️
So far I've finished my pump(all new hard parts and hi rev kit), reverse drum, input housing all set up (new HD sprag, 7 clutch upgrade, moulded pistons, stiffer springs), shift kit installed with sonnax 2-3 valve
All I got left is install new heavy duty sunshell, replace the seals and clutches related to the back half/output side of transmission
In fact if you read Danas hole size recommendations through the years they change often, and I don't think it's application specific.
And about the 2nd feed being bigger, it's all in the accumulator set up. The feed hole can be bigger (up to mid .090 range) if the accumulator is set up to match and a corvette servo used with the transgo springs. Dana used to be specific about the 1-2 accumulator piston, either use the late style without the three legs or grind the three legs off. I have no idea why he wants to grind the 10 nubs off of the piston. In the deep housing this will provide soft shifts at low throttle and firmer shifts with throttle (with the recommended feed hole size) And it can easily be changed by removing the pan and three bolts instead of the whole valve body.
IMO you need to feed the apply components to make them live and if you don't like how it shifts either deal with it or change it with the accumulators, a higher stall speed will cushion the shifts in the drivers seat (not necessarily at the transmission).
You can also do the firm third modification below. No, it doesn't effect the 3-2 downshift at all.
If I had cash the box will be filled with all sonnax goodness I wish I could afford
Blocking the 3/2 control valve doesn't have any negative effect? When you remove the spring what stops the valve from moving back and forth. Do you make a plug and put a spring on the side of the valve?
The only thing left that I wanted to buy. The unit I'm rebuilding had a burnt forward clutch assembly. I wonder if I should install a sonnax pinless accumulor piston for the forward one only just incase there was a hydraulic leak around the pin causing the failure. The valve body did look in good shape but can't figure out why the forward clutch failed. Unit did have 180,000km on it
-Block the 3-2 control valve
-Block the 3-2 down-shift valve
-Sonnax pin-less forward accumulator piston
-Sonnax pin-less 2nd accumulator piston
-Sonnax forward abuse valve end-plug
-Sonnax reverse abuse valve end-plug
-Sonnax O-ringed end-plugs
All of these valve-body changes are correcting circuit leaks normally found in the 4L60E valve-bodies.
Note: TCC valve-train and AFL valve-train are almost ALWAYS worn and should be corrected with tooling and new valve-train
Do people still block the 4th accumulator and remove the piston? Was thinking of doing that also. Do you just remove the pin, spring and piston and knock a checkball where the pin used to go?
How to you guys go about blocking off the 3-2 solenoid and valve and I'll do it
Was also thinking of disassembing the input drum again to add those oil feed holes in the new forward sprag I've heard Dana mention in other post
"Everyone hates those to firm 3-4 shifts......said no one ever!" That's a good one...They are not the same as the 2004R, which can have a very firm 3-4 WOT shift.
I can not find any instructions for blocking 3-2 valve. Can someone maybe post a link. If I spend any more time researching 4l60e things my wife will start to think I'm having an affair typing away on my phone all day lol
What about blocking and removing 4th accumulator piston?
You mean grind 4 notches like that?
Thank you for all the input. 1st gearbox lasted such a long time behind a modified engine I hope number 2 gets a good run too.
Looks like I got a few valve body mods to keep doing now. If there is anything else you think I should tackle while it's all apart let me know. I'll probably get it done end of the week due to work commitments.
Put some old end plugs or a spring or cut a dowel to length that makes it sit snug against the solenoid?
Looks like I got lots of valve body mods to keep doing now. If there is anything else you think I should tackle while it's all apart let me know. I'll probably get it done end of the week due to work commitments.
But. Since you increase the spring tension so much over stock those 5 smaller return springs aren't really fighting you enough to worry about any negative effects.
Even the new Sonnax input drum comes with new ones to install. Must have a benifits. From my experience car manufactures don't add parts (or should I say costs) that have no benifits
I also spin my motor to 7100 ( not 3-4 clutch pack friendly)
and road course my car.
"From my experience car manufactures don't add parts (or should I say costs) that have no benifits"
This is not necessarily true, Quick example would be blocking the 3-2 valve inboard.
