Flexplate - Covid?
Old Jun 19, 2020 | 08:43 AM
epfatboy's Avatar
Default Flexplate - Covid?
I'm not having much luck getting a replacement flexplate for a straight up Gen3 to 4L80E, the stock flexplate is broke. I'm running a 10.5" freakshow converter which uses a 3 bolt mount.
I have ordered a SFI unti from TCI but the frigging thing keeps getting delayed and I'm going to cancel if I can find a suitable replacement which Summit said they do not have!
https://www.summitracing.com/parts/tci-399754
I don't NEED the SFI rating but always nice to have, the Gen 3 engine is turbo'd so I would like a stronger than stock unit if possible but at this point I'm considering throwing anything in there!
Anybody have recommendations on a decent replacement for this setup? Really sick of waiting.
Old Jun 19, 2020 | 09:00 AM
epfatboy's Avatar
and this is why I can't have nice things both the FP's below have descriptions which make me wonder if they fit
This says LS but mentions PG and TH converters?
https://sdparts.com/i-21033980-hays-...%7Cyear%3D2005
This one requires spacers and bolts?
https://www.speedwaymotors.com/Chevr...80,395626.html
Old Jun 19, 2020 | 09:15 AM
bbond105's Avatar
Call WS6store or Texas Speed and Performance, they should may able to hook you up.
Old Jun 19, 2020 | 11:15 AM
Kfxguy's Avatar
Would this work? https://www.ebay.com/itm/CAT-RACING-...YAAOSwKRBbFaEF
this is the flexplate i'm using. No complaints. its thicker than stock for sure
Old Jun 19, 2020 | 01:46 PM
epfatboy's Avatar
I don't think so, pretty sure I need the 11.5 converter bolt pattern.
I was waiting on getting the FP before I took the tranny out, maybe I'll get that done tonight and measure up the converter, it might have provisions for an 11"+ mount pattern. But then again I just want to order as much improved stock replacement as I can get so I remember what I need to order when **** breaks. This is in a '74 C10 that already have a variety of parts from other doner years which I should write down!
Old Jun 19, 2020 | 01:52 PM
Kfxguy's Avatar
it has 2 or three bolt patterns......
btw, fwiw, I read several instances where people had issues (don’t remember what) with the tci flexplate.
Old Jun 19, 2020 | 05:01 PM
truckdoug's Avatar
i used prw ​​​​​​1834620 and its got 3-4 bolt circle diameters on it. you might need a snout extender thing though. I did.
Old Jun 19, 2020 | 08:16 PM
vorteciroc's Avatar
LOL!
I never have had an experience where obtaining a Flex-Plate was soooo difficult... LOL!
If worse comes to worse on a project... having a torque-converter made can be an easy solution to less common engine to transmission pairings.
Good Luck!
Old Jun 19, 2020 | 10:18 PM
clinebarger's Avatar
A very common issue with 4L80E Flexplates is wear in the Crank Adapter/Spacer where the converter pilots, This (In my opinion) leads to broken flexplates. If you have to reuse the existing adaptor.....Check it real well for wear!
This complete kit is in stock at the Arlington, Texas Summit Racing warehouse.......https://www.summitracing.com/parts/b...BoCwqsQAvD_BwE
Old Jun 20, 2020 | 09:28 AM
epfatboy's Avatar
Are you using that with a 4L80?
Old Jun 20, 2020 | 09:31 AM
epfatboy's Avatar
I don't have a spacer/adaptor It's a stock gen3 (4.8) to 4L80E pairing. and the converter/crank pilot is TIGHT! first time I dropped the tranny out I had to work at it and getting it back in wasn't a treat
Old Jun 20, 2020 | 09:34 AM
01CamaroSSTx's Avatar
Purchased a TCI flex plate through JEGS about three weeks ago and I'm still waiting.
Old Jun 20, 2020 | 09:36 AM
epfatboy's Avatar
Was this paired to a 4L80? If so was the adaptor to space out the FP AND snug the FP to the converter snout? Looks like the FP is dished, the stock one I have isn't.
Old Jun 20, 2020 | 12:53 PM
truckdoug's Avatar
4.8/80e combo yes it has some dish. the part i used was more a pilot extender than flywheel spacer. call summit, they have them and they are mostly decent on the phone
Old Jun 20, 2020 | 03:59 PM
epfatboy's Avatar
Got it, so something like this versus a spacer, thanks!
https://www.summitracing.com/parts/s...4/applications
I'll still give them a call once I drop the tranny and measure the snout... maybe tonight if it cools off a little bit.
Old Jun 20, 2020 | 11:53 PM
Okay.....That's not how GM piloted the 4L80E converter on LSx engines.(Except '99 & '00 extended crank LQ4's) which basically had the spacer incorporated in the crankshaft.
Being a 4.8L doesn't mean anything to me as Savanna/Express 2500/2500 vans had 4.8L's & 5.3L's paired with 4L80E's & used the SAME adapter & flat flexplate the '01 & up LQ4 used.
I can't believe people use aftermarket pilot extensions when the correct OE stuff is readily available. Or just simply have a extended pilot converter built for a dished 4L60E/6L80E flexplate.
Old Jun 21, 2020 | 08:50 AM
epfatboy's Avatar
Right, I’d really like to get the right flat FP and not deal with a spacer or adaptor but I’m having a hell of a time finding the right FP that has the right converter mounting pattern and is a bit stouter than stock. Nothing is ever simple.
never got under the truck last night, decided working on my 25 year old mut of a bike was going to yield a lot more results.
https://photos.app.goo.gl/SKLgyGRtmozMVVi37
[img]blob:https://ls1tech.com/6967da6b-2d8b-4def-b614-b85a82143181[/img]
Old Jun 21, 2020 | 09:39 PM
So you have a dished flexplate & extended pilot converter??? And a 11.5" bolt circle/pattern???
Old Jun 22, 2020 | 10:22 AM
mjs1012's Avatar
There's no issues running a flexplate spacer, plenty of people do it, so not sure why you're so against it.
If you're looking to go the cheap route, you can get an ATP Z-270 off Amazon for like $60. It's a flat flexplate that includes the extension. Or you can call a company like FTI and they can hook you up I'm sure with something decent.
FWIW I have a long crank lq4 and custom built 4l80e bolt pattern converter and run a flat SFI JW flexplate that has both a standard ls bolt pattern and 11.5" 80e pattern. You'd need to get a spacer since it's not included. Part number is 564-93019-LSC.
Old Jun 22, 2020 | 07:40 PM
mrvedit's Avatar
Moderator
I'm with Clinebarger that the pilot extensions are the cheap&lazy man's "solution" and a bad idea. I recall posts here where they caused mysterious rattling sounds. A $60 kit consisting of the spacer and 6 longer bolts and you have duplicated GM's proven method.
