First 4l80e build. Here we go!
Old Nov 2, 2020 | 08:10 AM
  #141
Novapat67's Avatar
Originally Posted by MaroonMonsterLS1
They make different thickness pump washers.
That would be preferable to the shim, but the shim should be OK
Checking servo clearance needs to be done with the servo totally disassembled with only the servo and pin together.
Remove the accumulator, spring, and the spring on the servo pin.
Your clearance "starts" when the seal is totally captured in the sealing bore. Once you can no longer see the seal...count that as zero and go from there.
.100 will be fine.
This is how I currently have the servo set up for testing. I was just having some trouble seeing where to start the measurement. I will check it again tonight, starting the measurement as soon as I cannot see the seal slot anymore.. thanks for your help!
Old Nov 4, 2020 | 07:11 PM
  #142
Novapat67's Avatar
So the shim I have will not fit so that means I need another selectable washer. My rear endplay is .006. Front endplay is .025. The next biggest selectable pump washer is .105(currently have .090). That will leave me at .010 front endplay. Does that seem too tight?
Old Nov 5, 2020 | 07:51 AM
  #143
MaroonMonsterLS1's Avatar
.010 should be alright if the rear is .006
Old Nov 5, 2020 | 08:45 AM
  #144
Novapat67's Avatar
I'll pick up another washer today. Fingers crossed for final assembly tonight!
Old Nov 7, 2020 | 04:41 PM
  #145
Novapat67's Avatar
I assembled the pump with the new washer and the endplay came in at .010. That works for me. I have a bunch of washers in a bag that came with my rebuild kit. I am trying to figure out which one is the TCC o-ring that goes on the input shaft. Also, I seem to have misplaced the little cup that goes on the spring for the manual 2 brake band servo. I will try to find it or get a new one next week, unless it is possible to leave it out.
I am very excited to be this close to finishing!
Here are some pics of the possible o ring I need to use and the cup I am missing.
https://imgur.com/a/pbcn901
Old Nov 8, 2020 | 08:00 AM
  #146
truckdoug's Avatar
the green one *looks* like the ones that come in kits now days. they used to be black.
i've never seen or used that cup thingy in the second pic
Old Nov 8, 2020 | 08:58 AM
  #147
Novapat67's Avatar
Rad! Thanks man!
Old Nov 9, 2020 | 07:13 AM
  #148
Green O ring
Yes, you should use the cup
Old Nov 9, 2020 | 09:12 AM
  #149
truckdoug's Avatar
what does the cup on the engine braking apply servo do? ive never seen one
Old Nov 9, 2020 | 09:31 AM
  #150
keeps the clip retained so it cannot slip out
Old Nov 9, 2020 | 09:32 AM
  #151
Novapat67's Avatar
I think my kiddo might have gotten ahold of it and it's gone forever. I can take it back apart and find one somewhere if need be.
Old Nov 20, 2020 | 05:46 PM
  #152
5.7stroker's Avatar
This thread is pure eye candy! Thanks to all that contributed! Read every word of it!
Old Nov 20, 2020 | 05:52 PM
  #153
Novapat67's Avatar
My hope when I started this thread was that it would be helpful to other people. Once I get a new dipstick, I will have it all back together! Thanks to everyone for all the help!
Old Nov 29, 2020 | 09:36 PM
  #154
Novapat67's Avatar
Thanks again everyone. I definitely couldn't have done it without the help of all the people in this thread. I am excited to put the engine and transmission back in the car this week!
Finished pic!
https://imgur.com/a/HIO2w09
