First 4l80e build. Here we go!
Thanks to clinebarger for the informative posts and truckdoug for the helpful YouTube vids.
Here is the plan so far:
-Dual feed using Jakes Performance recalibration kit I already have
-Upgrade to a stronger intermediate clutch spring assembly
-Replace whatever clutches and seals I need to along the way
-Tighten up the friction clearances
-rollerize the output and possible rollerize the forward hub.
-Sonnax tcc regulator valve kit
-Sonnax line pressure booster kit
-HD intermediate snap ring
If there are any other must-do modifications or anyone has any other input, I'm open to suggestions. Thanks!
Here is what I am starting with. It's a 1994 4l80e:
https://imgur.com/a/iZecaWo
https://i.imgur.com/tJEtbAQ.jpg
For a customer unit I will always replace.
For a personal unit...those clutches will go another 100k miles
The ones you have look decent, but they are the older design/ material for the Forward, Intermediate, and Direct clutch packs.
I would recommend at least purchasing the newer material (High Energy Borg-Warner) friction plates for those 3 clutch packs.
Sometimes they work perfectly for a long time... and other times they crack out of no where!
There is an updated design (Steel instead of cast Aluminum) for these also.
use the green high energy as stated
When vortec mentions the steel pistons, he is referring to what are commonly called "molded" pistons. Where the lip seal is molded right onto the piston. may be easier for you to find them that way.
For the directs, a molded piston, with 6 frictions and 6 of the thin forward (.077) steels will fit like a dream and usually nail the clearance with no other changes
That's it.
Direct drum center seal splits two separate hydraulic circuits.
Removing that seal and plugging the center support feed will "dual feed" the clutches.
Otherwise...yes...use a 1997+ paper/rubber and friction kit.
That's it.
What is that cylinder around the output shaft? I have not seen that on other 4l80e's I've looked at.
Here are some pics:
https://imgur.com/a/CkUAfKf
i usually remove them and weld the hole on the yoke.
Also, thank you so much for all your videos on YouTube. They are super helpful and have given me the confidence to tackle this myself!
