First 4l80e build. Here we go!
Old Sep 28, 2020 | 10:47 PM
  #101
vorteciroc's Avatar
are these the "waffle frictions" ? I use those in the direct and GPZ's with a wavy plate in the fwd for ck-style 80e transbrake (fixed line pressure)
They have a partial waffle pattern...
But no, most people using that term are referring to Raybestos Green waffle frictions for a THM400.
Not the OEM Allison frictions.
Some people also confuse the name Allison (GM/ Detroit Diesel) with the name Allomatic (Raybestos).
Old Sep 29, 2020 | 02:38 PM
  #102
Novapat67's Avatar
I had a thought. Would I need a late intermediate piston to have enough room for a wave plate? I'm not sure if the early and late pistons are different. I will measure again tonight to see how much clearance I have with no wave plate. I know things are skewed with the clutches being soaked already but at least it would give me another data point.
In hindsight, if I had to do this over again, I would have tried to start with a later model core.
Also, all of the clutches I am using are flat and not waffled
Old Sep 29, 2020 | 03:22 PM
  #103
MaroonMonsterLS1's Avatar
Shoot for .030 wet
It will be fine
You can usually run an old school th400 wave. Right against the bottom friction is ok
Old Sep 29, 2020 | 07:11 PM
  #104
vorteciroc's Avatar
1991-1996 cores will have a slightly taller intermediate piston and a different clutch stack.
1997+ cores use a slightly shorter piston that uses an integrated waved steel (the height of this piston and steel together are aprox. the height of the 1991-1996 piston).
I personally prefer the earlier cores (1995 and 1996 are my favorite) I prefer this lube-system and over-run section for 1,000+.
Any of the cores (regardless of year) can be made to work, by swapping parts from other years though.
No matter what year core I build... I have to use parts from other years.
1991- 1996 units, need a some parts like the carrier and band from the later year cores.
1997 units need some parts like the early style hollow intermediate-shaft, and the over-run section from the earlier year cores.
Old Sep 30, 2020 | 10:24 PM
  #105
Novapat67's Avatar
So the set up of the intermediate clutches has been driving me crazy. I measured it again tonight and realized that I've been measuring it in a difficult way by trying to get the feeler gauges between the top friction and the bottom of the pressure plate. It's a lot easier to measure between the snap ring and the pressure plate instead. With the .070 wave plate with the friction right on top of it, and 3 more steels(4 frictions total, I'm at .089. I feel like .019 will be too tight if I add the steel back on and way too loose without it. Any thoughts?
Here is a vid of me measuring the clearance:
https://imgur.com/a/qkSN37Q
Old Oct 1, 2020 | 09:45 AM
  #106
Remind me what thickness steel plates and friction plates you are using.
Assuming the "thin" .070 borg HE frictions and the .077 steels?
If that is the case, swap 2 of the .077 steels for some th400 .100 steels.
So the stack should have
1x .070 wave
2x .100 steel
1x .077 steel
4x.070 friction
Old Oct 1, 2020 | 09:50 AM
  #107
vorteciroc's Avatar
And seriously people....
He does not mean stack the components in that order!
Old Oct 1, 2020 | 11:52 AM
  #108
Novapat67's Avatar
1x .070 wave
2x .100 steel
1x .077 steel
4x.070 friction
I just went and measured to be sure. My steels are .074 and my frictions are .070. My wave plate is also .070. The frictions have been soaked already.
Old Oct 1, 2020 | 02:45 PM
  #109
use 2 thick th400 steels. they will measure .100
That will soak up a good bit of your clearance
Old Oct 1, 2020 | 02:50 PM
  #110
Novapat67's Avatar
Perfect! I will pick some up today!
Old Oct 1, 2020 | 07:04 PM
  #111
vorteciroc's Avatar
Excellent!
Note: It would be a good habit of assembling two identical stacks of feeler-gauges (lets say the 0.089" that you used) and insert them in to different positions around the clutch stack, at the same time.
This is a slightly more accurate method of measuring clearance; as not to tilt the backing-plate and get a false reading (larger).
On the Forward and Direct drums where the backing-plate sits on a lip/ ledge of the drum...
Take your top friction and the steel below it out.
Flip them over together.
Placing the top friction on the next lowest friction.
Then the steel at the very top.
The backing-plate will have that steel under it now.
Place feeler-gauges between the steel and the backing-plate.
No worrying about gouging a friction plate now.
Old Oct 2, 2020 | 07:36 AM
  #112
I'm a big fan of using spark-plug gap tools.
Like this one.
In so many locations it is easier to get in than a feeler gauge.
And easier than a dial indicator on a flat table.
Agree that installing 2 opposite each other is usually best, but if you can't, I usually compensate with about .002 being the difference from just installing on one side
Old Oct 2, 2020 | 04:49 PM
  #113
vorteciroc's Avatar
Very nice Mr. Monsta!
Old Oct 9, 2020 | 10:50 AM
  #114
Novapat67's Avatar
Work has been very busy so I haven't had a lot of extra time to work on this. I should have the last seals I need and all the steels to set everything up.
Is there a post or quick explanation for air testing? I mostly mean which port to put air to, to test which assembly? Thanks
Old Oct 9, 2020 | 11:16 AM
  #115
The center support bolt is where you test the int. clutch
The holes on either side of it are for testing the direct clutch. You likely have one hole plugged for the dual feed. So test at the other one.
The Fwd clutch and overruns can both be air checked on the bench by turning the pump upside down and setting it on top of something. Then assemble the input shaft, OD planet and everything up to the fwd drum.
The OD clutches can be tested via that torx bolt in the case.
The band can be checked via the hole that feeds it in the case. You must have the cover and gasket in place and torqued.
I check everything with 40psi shop air
Old Oct 9, 2020 | 10:35 PM
  #116
Novapat67's Avatar
Thanks for the info. Super helpful!
I got the seals on the ck direct piston and have the direct sitting at .058 clearance with no wave plate and 6 frictions. Will that work?
Old Oct 11, 2020 | 11:28 PM
  #117
vorteciroc's Avatar
Good to go!
Old Oct 12, 2020 | 11:35 AM
  #118
Novapat67's Avatar
Good to go!
Awesome! I will check the intermediate piston with air tonight and then install the forward and direct. It is probably a bad idea to install the 4th clutch without replacing the seals right? It looks intimidating but I can give it a go if necessary.
Also, I've been using the ATRA 4l80e Manual by Cliff McCormick in addition to the ATSG manual. The ATRA manual has great full color pictures which have been very helpful.
Old Oct 13, 2020 | 09:55 AM
  #119
Novapat67's Avatar
Well, last night did not go smoothly. First, I air tested the intermediate clutch. It actuated fine but I need to get a better air nozzle as mine was leaking. I suppose it wouldn't actuate if there was a leak at the seals so that should be good.
I soaked the frictions and assembled the direct. I went to install it and realized I had not compressed the sealing rings on the center support enough so it would not slide over. I did compress them with a hose clamp but I didn't slide the direct over them to make sure everything fit ok. I will have to pull the gear train out and remedy this.
For anyone else following along, make sure you bench test everything!
I also started working on my boost valve kit and can't get the old one out. Even after the snap ring is removed, it catches on the bore. I will have to lightly file a chamfer into it so it doesn't catch.
Here's a pic: https://imgur.com/a/cwL8AQN
Old Oct 13, 2020 | 10:07 AM
  #120
truckdoug's Avatar
gently pry it with a J-pick from the spring end. it'll go. i deburr the edge of bore with a tiny wire cup on a 1/4 shank in a pnuematic die grinder.
yea a rubber tipped air schnozzle is the way to go
