4l80e front thrust adjustment location idea
But today I was looking at the torrington bearing in the face of the forward drum that the overrun sits against and I just happened to have some th350 rear shims on the bench and it hit me...what if I slip a .015 in under the torrington bearing? seems like it works really well.
Input is appreciated
As does the selective plastic thrust washer at the back of the pump.
There is really no need for a shim on the over-drive ring-gear though... and excessive shims here can cause sealing-ring issues.
I like to reference the THM400/ 3L80 for part of the end-play explanation here.
For the THM400 front end-play stack-up:
-Build up through the intermediate clutch pack, retained by its snap-ring in the case.
-Leave out the direct clutch drum.
-Install the forward clutch hub onto the intermediate shaft.
-Install the thrust washer on the back of the forward hub.
-Install an empty forward drum.
-Install the pump to case paper gasket.
-Install the selective plastic thrust washer and pump assembly.
This is what is needed to measure the end-play.
The direct drum is not a factor... essentially there should be float here on a stock assembly.
The thrust washer between the direct drum and forward hub also should not be a factor (unless too thick, lifting the hub off the intermediate shaft).
The 4L80E stack up would be the same, but also include the over-drive planet assembly with the input-shaft.
The bearing will lift the fwd hub up off the mainshaft and now the thrust path will not travel through the mainshaft but rather through the direct drum.
Using this method on a th400 the fwd drum will be moved closer to the pump and I like that for sealing ring depth.
I do this on an 80e also
Can only do this with a bearing, don't do it with a washer
This will direct thrust loads to the center-support instead of down further through the gear-train.
I would love to hear more...bearing part number and cut specs if you dont mind sharing
The direct-dum should more or less "float", in a sense like the reaction carrier.
The direct-drum is not very well supported in the stock arrangement... and is one of the many reasons why the intermediate sprag is relatively delicate.
Some builders will machine the center support for a bushing or bearing that supports the direct drum from the sealing-ring bore.
You can see a bronze bushing bellow the sealing rings that help reduce drum wobble, in the image bellow:
I personally prefer machining a pocked in the face of the center-support for a bearing as it supports the direct-drum and changes the thrust path for multiple improvements.
In addition, I usually also use a Billet sun-gear shaft that has a very tight press-fit into the direct drum; to provide even more control/ support of the direct drum.
The pocket that gets machined into the center support can be done so, as in the article bellow:
Article
The 4L60E on the other hand can be fully rollerized very easily.
