2BFAST'S 69 Camaro 4L60E Build
#161
I've done it both ways.
I like to leave that check ball active.
Either way will work.
To each their own
To each their own
#163
"I already have a nice set of GM 5 pinions I plan to use. Iv had them for awhile now so I do plan to use them"
don't
Sell them to someone who thinks they're worth a damn and spend the money on the input.
They're not...they are a downgrade from the 4 pinion
Less window area for lube. More pinions that require more lube. Powder metal carrier. I can go on
You WILL NOT break a 4 pinion from power. Period. Especially if you aren't running the sonnax input.
don't
#164
don't
don't
#165
He is saying that if you are not running the Sonnax billet input shaft, that you will break the stock input shaft before you will the 4 pinion carrier. Lack of lubrication or failed thrust bearings is what kills plant pinions, not hp.
#166
So now the question is this. I currently have the reinforcement collar already pressed on my drum with the stock input shaft. I have the billet Sonnax shaft on its way. So that poses the question. Whats the process to press out and in input shafts with the collar already on? I called Sonnax tech support and off hand he didnt know either. Said he was going to get with engineering and call me back.......
I know the instructions from Sonnax say to NOT press on the collar on the drum first then press in the shaft. Which makes total sense....but now im in the opposite situation.
Will report back...
Will report back...
I have noticed that their Smart-Tech housing ad with shaft, the 77733-11KA model as an example, says they use only the latest, brand new GM parts... and their shaft says:
"Smart-Tech input housing kit with heavy duty input shaft 77733-11KA fits 300mm non-reluctor style units. The high-strength shaft features many unique refinements available only from Sonnax, including a unique design that protects against failure from stress cracks. Both the housing and shaft also are available separately."My bet is there's some type of heat treating as well as shot-peening too. You'd be surprised what a soothing overnight bake and shot-peening can do for input shafts and forward drum shafts--in 200-4R's, those 2 processes ended the snapping & fracturing.
BY THE WAY--the 11KA had that reduced diameter ring/step less than a half inch tall on the shaft, like found on some of the 4l65e's I've seen...
#167
to your first post:4 pinions don't fail from power.
you saw a lube failure
to your second post: No, I did not make a typo. I don't think it was that tough to understand but read it again.
I said you won't break a 4 pinion, if you are running a stock input shaft. Implying that the input shaft will break long before the planetary does...
the input would be a 10a fuse and the planet is a 30a fuse...if those are in line together...you know which will blow first
to your third post: mentioning "billet" shafts is common in the industry
sometimes they are a forging and are roll formed in the spline area
some start as raw bar stock and get turned into a shaft...easily considered billet...meaning coming from a billet blank "semifinished iron/steel/aluminum etc bar or block"
And
And
The following 2 users liked this post by MaroonMonsterLS1:
matermark (12-09-2021), vorteciroc (06-10-2021)
#168
Great read,, question,, so why did GM make the 5 pinion change? I have a 4L65E recently rebuilt. Haven't used it yet..
Was it a RPM thing ?
Just pondering thanks!
Dave
Dave
#169
GM did alot of screwed up stuff with transmissions that didn't make sense
at all
they did it because they went to a different material and process for the carrier and they needed an additional pinion to distribute the load of the carrer. Ultimately, it is my personal opinion that they made a CHEAPER planetary setup to offset the cost of the shafts in the 4l65 and 4l70 transmissions.
by all measures, the 5 pinions are objectively worse than a 4 pinion...in my opinion
at all
#170
Interesting,, in the transfer cases from New Venture (NP231 and 241) the 241 6 pinion is SOOO much quieter than the 3 pinion in the 231.
I always kinda associate wear with noise..
We shall see how the 4l65E survives in the Jeep.. Its not a crawler or bogger so I didn't go too fancy, minor upgrades only and had the
builder set it for a "just firm" not hard slamming shift. I'll see how he did this weekend!
Running with a Terminator X-Max so I can adjust a bit..
#171
As I have said many times now... the 5-Pinion Planets were a cost savings measure.
They are absolutely inferior!
GM was not trying to offset cost, but just increase profits.
There are now several Threads on this forum going over why the 5-Pinion Planets are inferior.
#172
Nobody seems to search for info regarding this.
Anyone have an opinion?
The following users liked this post:
Tranzman (06-11-2021)
#174
Either way, I say it can't hurt. I vote yes.
The following 3 users liked this post by dixiebandit69:
#175
Vortec I'd be happy to write that up with ya
as well as covering other parts that are an utter waste of money haha
The following 4 users liked this post by MaroonMonsterLS1:
#176
I get asked about them all the time. It would be nice to have something to direct them to. Cause you know if its on the internet it's gotta be true!!!😄
#177
I don't know why people don't do searches tho. You literally punch your question into Google and just simply type Ls1 at the end and the info is endless. (Not directed at you dixiebandit69 )
Example: Google search....5 pinion planetary 4l60e Ls1
#179
