Is there diagram of how to air check a assembled trans with the valve body off? The flow charts I'm finding are for the valve body it's self, not below the separator plate. Or is there a better way? Thanks
vorteciroc
close
- Join DateJun 2008
- LocationNitro Alley
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Liked:1,377 Times in 945 Posts
If you assemble the transmission in the order shown in a ATSG manual:
-You can air-check the Low-Reverse clutch pack with the valve-body off
-You can air-check the separate chambers of the 2-4 Servo assembly with the valve-body off.
As far as air-checking the other clutch packs go, you would place your pump assembly down so that you could install the assembled reverse-input drum and assembled input drum all together... Air-checking these 4 clutch packs via the passages on the back-side of the pump assembly.
Note: if you build a good amount of these regularly... the pump assembly and valve-body can be modified into air-check tools to test the transmissions before final assembly.
This is something that I used to do when I was starting out with my business...
After you have done enough of these, you will develop a feel for most everything and not have to bother with making air-checking tools.
I also use a transmission run-stand these days.
2BFAST
close
- Join DateApr 2005
- LocationN.E Missouri
- iTrader Positive Feedback100
- iTrader Feedback Score(11)
- Liked:233 Times in 184 Posts
Last one I did I had an issue at first getting the forward and 3/4 to air check. Not sure what happend? After working it quite a bit, disassembling, then reassembling it it finally started to air check. FWIW, I used scarf cut sealing rings on the input shaft? Originally Posted by vorteciroc
Quote:
I've used these "step cut" input seals on 700s. Dana includes them in his kits. Petty good if you dont have access to the resizing tools. I also used the blue scarf cut seals on the stator. Not sure about scarf cut on the 4l60e?
vorteciroc
close
- Join DateJun 2008
Most people today use the "Steel/ Bonded Pistons", which makes things pretty much fool-proof.
It is easier for a beginner to have an issue with the lip-seals used on an early aluminum apply pistons.
As long as the Scarf-cut PTFE sealing rings were installed with the ring-ends correctly placed...
They usually air-check fine.
MAKE SURE that the small green O-Ring gets installed towards the bottom of the drum first or around the same time as the 3-4 clutch apply piston.
And make sure to lubricate it with assembly lube or ATF once it is installed.
This O-Ring is often forgotten by beginners.
I often crank up the line pressure on these units and prefer the solid-PTFE rings.
I didn't have any leaks on the low reverse piston or on the input drum assembly. The reverse drum is hard to air check and I should of air checked all three components as an assembly before installing them into the trans.
I used solid-PTFE O-rings and slid in pretty easily ( I alittle problem with resizing the pump O-rings for the rev-drum but got the slide in. I'm sure every thing will work, BUT I think of to many what ifs.
Has anyone ever made a wet pressure test tool to run fluid into pump at line pressure ? Also, is there a way to put a gauge on afl pressure?Originally Posted by vorteciroc
If you assemble the transmission in the order shown in a ATSG manual:-You can air-check the Low-Reverse clutch pack with the valve-body off
Tranzman
close
- Join DateJan 2019
- LocationRoxana, IL
- Liked:490 Times in 329 Posts
Quote:
This is an old thread and you may get more if you start your own.Originally Posted by azreeal
Has anyone ever made a wet pressure test tool to run fluid into pump at line pressure ? Also, is there a way to put a gauge on afl pressure? I use an air test plate that I cut and drilled myself out of a piece of 1/2" of aluminum plate. I can test FWD, OR, 3-4, Rev, L/R, P/R, 2nd, 3rd & 4th circuits. I do need 2 sources of 40 psi to test the 2rd release..
