Full manual 4l60e 4200 histall soft shift
Old Jun 15, 2021 | 05:43 AM
Savage_86's Avatar
Default Full manual 4l60e 4200 histall soft shift
Hey guys i have a built full manual 4l60 and have just changed the convertor from a 3600 to a 4200 and since this i have a soft 2/3 shift.
Had a run with WOT and the 2/3 shift belts limiter so i backed off and it completed the shift.
With the 3600 stall i always had a firm 1/2 and 2/3 shift.
What do you guys think and best action to take for a diagnosis Cheers
Old Jun 21, 2021 | 02:11 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Did you change anything else during the converter swap?
Is the 1-2 shift still firm or is it noticeably different as well?
Did you check that the unit was filled properly with fluid?
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Jun 21, 2021 | 05:47 PM
Savage_86's Avatar
Hey mate nah i did noting else, the 1/2 shift is still perfect and sharp. if double checked adjustment of shifter and fluid level us spot on, i even added 500ml to see if that made a difference
Old Jun 21, 2021 | 06:33 PM
vorteciroc's Avatar
What are the Third-Exhaust, Third-Feed, and Third-Accumulator orifice sizes?
What is the Line-Pressure during the 2-3 Shift... and how well does it recover?
Old Jun 21, 2021 | 06:34 PM
vorteciroc's Avatar
Any Check-***** omitted?
Old Jun 21, 2021 | 06:50 PM
Savage_86's Avatar
i have no idea mate, the box was built by a shop, what pressure should i expect on the 2/3 shift?
going to have to setup a gauge so work this one out
Old Jun 21, 2021 | 07:00 PM
vorteciroc's Avatar
Every Builder and every 4L60E Transmission is going to differ in Line-Pressure depending on how the Transmission was Built.
However in a performance built 4L60E... the Line-pressure should at least be in the 230Psi to 245Psi Range.
...Even higher on High HP Builds (over 700 HP).
Old Jun 21, 2021 | 07:17 PM
Savage_86's Avatar
yeah understandable, car makes 450rwhp so id say it been built to handle 600+ ill setup a gauge and see what its doing.
i cant getvit to slip loading in 3rd so hopefully a valve body issues 🤞
