4L60E Dipstick Stopper
Old Apr 26, 2022 | 10:44 PM
Mazda_B5300's Avatar
Default 4L60E Dipstick Stopper
Does the dipstick bottom out on the dipstick stopper in the 4L60E?
I'm trying to get my proper dipstick alignment/depth with a new dipstick tube. I was thinking I could temporarily shorten my tube, bottom out the dipstick, then measure how much longer the tube needs to be and lengthen the tube.
Does this make sense or will my fluid level be way off on the dipstick?
Thanks in advance
Old Apr 27, 2022 | 01:06 AM
bbond105's Avatar
Mark full fluid level on the dipstick level with the oil pan rail or just a little above the rail.
Old Apr 27, 2022 | 08:11 AM
From what I read, the way you describe is the proper way to do it. But I'm curious if my way will work as well.
My transmission is in my truck and I don't want to remove the pan if I can avoid it.
Old Apr 27, 2022 | 09:25 AM
tayto's Avatar
how do you know the full mark was correct in the first place. why are you changing the dip stick tube? my experience with dipstick stoppers is they don't stop the dipstick, only if it were to break off. ie: there is a gap
Old Apr 27, 2022 | 06:11 PM
I don't know that it was correct in the first place. But I had to change the tube because the OEM steel tube doesn't fit in my Mazda. So I cut off the bottom 4" and the top 4" and I have rubber hydraulic hose in between. I was thinking that the way I described might be easier than measuring the overall length.
Old Apr 28, 2022 | 12:09 AM
tayto's Avatar
1. your modified dipstick tube, while creative, sounds like a bad idea.
2. once you get your dipstick tube sorted out drop the pan and mark full
Old Apr 28, 2022 | 05:47 PM
dixiebandit69's Avatar
What's so bad about it? It sounds an awful lot like a Lokar dipstick tube.
Old May 1, 2022 | 02:14 PM
For anyone who wants a DIY Lokar dipstick tube, the distance from the bottom of the transmission housing, ie where the pan flanges up, to the top of the dipstick stopper is 1.5". This is for a 4L60E from a 1995 Suburban with the shallow pan.
Hope this helps someone in the future.
