Rebuilt 4L60E issues. Finally fixed!
Old Jun 25, 2022 | 02:21 PM
  #141
atlsoldier27's Avatar
also, does anyone use the gold spacers in corvette servo? I noticed it had one and am wondering if maybe it is my problem. Maybe putting to much pressure on the band.
Old Jun 25, 2022 | 04:23 PM
  #142
tayto's Avatar
The gold spacer from transgo is kind of a hack way to get the servo pin travel into spec. the recommended way is to get the sonnax extra long pin and grind it until you get your desired travel (about 0.060"). this spec is way smaller than what is recommended in manuals BTW. i don't think "pushing too hard on the band" is your problem. if the travel is too tight or too loose and would cause weird shift timing into 2nd which I don't recall being a problem? if the clearance was way tight i would think your band would be burnt and slipping into 2nd. i had a 700r4 i did where the servo pin had been cut incorrectly and actually dug into the band and causes slipping into 2nd.
I still think your problem is cross leaks (valve body) related but I have no evidence at this point
Old Jun 25, 2022 | 04:34 PM
  #143
You could be correct and I am not doing all of this because I think youre wrong. I am doing this as a learning point and also to make sure that there isn't anything else wrong. If I knew for certain that the second valve body I have would work, I would try to use it, but I am not certain. I also do not know for sure how to get an exact match of the VB for the year I have.
Old Jun 25, 2022 | 05:58 PM
  #144
tayto's Avatar
Ok, let's clarify here... The OTHER valve body you have is a '95 correct?
Which valve body did you get vac tested? The original '97 or the '95?
EDIT: i believe the 95 units had a PWM 3-2 solenoid and 96+ went to an on/off arrangement. i also think the tcc solenoid was different. blocking the 3-2 valve is a normal practice around here, just use the correct solenoid to avoid CEL, so that isnt a problem. I believe same with the TCC solenoid, install the correct one and move on.
​​​​​you could use a 95 transgo plate and gaskets and it should work. however i have never done this so cannot recommend it. maybe @MaroonMonsterLS1 could help here? i have asked him interchange questions before. I still think fixing your '97 VB is the way to go...
Old Jun 25, 2022 | 06:03 PM
  #145
bbond105's Avatar
Same here. I don't think it is mechanical. It's a hydraulic or electrical problem.
Old Jun 25, 2022 | 08:30 PM
  #146
I will continue to peruse the valve body and see what comes up.
Old Jun 27, 2022 | 08:49 AM
  #147
Everything is reading over 19”
Old Jun 27, 2022 | 12:49 PM
  #148
I have the trans all the way apart now. including bottom spring cage.
Old Jun 28, 2022 | 07:46 AM
  #149
2BFAST's Avatar
Well, its one thing to disassemble it. But its another finding the route cause while doing it. What did you find?
Old Jun 28, 2022 | 08:53 AM
  #150
Multiple things. All the apply pistons in drum were so loose that they wouldnt stay together with the seals. I also found two metal plates in the bottom that were upside down I believe. If I am correct, there is a notch in the ring that has to face a specific way, two were backwards. I did not measure clearance of clutches as I am going to be getting a new kit anyways, with a Zpak. all gears and splines looked nice. Im not sure how to tell about bushings though.
Old Jun 28, 2022 | 10:08 AM
  #151
bbond105's Avatar
Do not use a Zpak,use BorgWarner High Energy 3-4 frictions.
Old Jun 28, 2022 | 10:27 AM
  #152
is there a reason for that? I thought Zpak was the best for 3-4?
Old Jun 28, 2022 | 10:36 AM
  #153
Amazon.com: Chevy 4L60E Transmission Raybestos ZPAK Transmission Master Level 2 Rebuild Kit 1997-03 : Automotive Amazon.com: Chevy 4L60E Transmission Raybestos ZPAK Transmission Master Level 2 Rebuild Kit 1997-03 : Automotive
the exact kit I was going to get.
Old Jun 28, 2022 | 11:16 AM
  #154
mrvedit's Avatar
Moderator
Nope, perhaps the worst choice available now. They might have better than the frictions in the original 1994 4L60E when engines were 300HP, but they absolutely do not hold up with modern LS engines.
They haven't been mentioned much here lately because all the pro building tried hard 5-10 years ago to get everyone away from them. They are disappointed that Raybestos still sells them, especially because their GPZ frictions are much better.
Back when I was testing everything and rebuilding/swapping my trans every few months, I recall testing the ZPak; I installed them with their recommended .050" clearance and a few months later they had worn to .100" clearance.
Old Jun 28, 2022 | 11:27 AM
  #155
okay, sounds like i need to find a different kit. something 300 or less if anyone can help me with that. for a 97.
Old Jun 28, 2022 | 12:10 PM
  #156
bbond105's Avatar
As mrvedit said the Zpak is an inferior product.
I get my parts from Whatever It Takes Transmission Parts. It you can find a local distributor you can get the parts cheaper than ordering online. Whatever It Takes Transmission Parts allows you to pick and choose the parts you need without having to buy a kit full of parts that you don't need. With your trans having just been rebuilt you shouldn't need to replace all of the fictions and steels.
Old Jun 28, 2022 | 12:31 PM
  #157
Okay, I will keep all the parts I have other than the pistons. Would you recommend chaining any o rings or seals?
Old Jun 28, 2022 | 02:24 PM
  #158
bbond105's Avatar
Depends on if they are still pliable, damaged and if they fit correctly. It may be a good idea to get a paper and seal kit, that way you will have any o-ring or seal you may need and a new pan gasket. I always order a few extra pan gaskets just in case I need to make an adjustment.
Old Jun 28, 2022 | 02:59 PM
  #159
tayto's Avatar
I would contact Dana @ Probuilt Automatics. He can sell you a complete kit with all of the updates, along with thw correct cluthes and steels. He also sells a modified Transgo shift kit that is pretty good vs DIY shift kit.
Old Jul 2, 2022 | 07:09 AM
  #160
New “performance high heat resistance” bonded pistons and a full seal kit is on the way in today. Will be working on this a lot during the week and will most likely ask questions through the process. I appreciate everyone’s input and patience with me through this.
