4l80e feels like its slipping
Here is the link to the original 4l80e build thread: https://ls1tech.com/forums/automatic...e-we-go-8.html
Here are the high points:-1994 Core
-All new BW HE Frictions
-Jakes Performance Recalibration kit
-All new seals/bushings
-Rollerized output
-HD Intermediate snap ring
-Dual Feed Directs
-TH400 style Direct Clutch piston(from CK Performance, milled to fit)
-3-4 Accumulator delete
-Bonded steel forward apply piston
-New reaction carrier sprag
-New Boost Valve kit
-TCC Regulator kit
It seems to be slipping and is also very soft shifting, even from Park to Reverse. I know some of this may be the initial tune file, but i think it is more than that. I am waiting on a pressure transducer in the mail to log pressures. Before I installed the pan, i was sure to adjust the braided dipstick to be sure it was set at the right height for proper fluid level. It looked to be about a half quart low when I measured it after running for a few minutes before my drive. I went on a 15 minute drive and did some datalogging to try to see what is going on. When I got back and parked it, I went to check the transmission fluid level with the car running to see exactly where it was at warm. When I pulled the dipstick out , ATF erupted out of the dipstick tube and sprayed all over the car!
What else should I check before I get the pressure transducer? I attached some of the data logs from the drives I took. Thanks in advance for any help or advice!
Data Log 1
Data Log 2
If pressures are good, but you have slipping in reverse and Third/ Fourth...
Your Direct Piston may be too short/ shallow in the Drum...
Allowing a Steel Plate to drop into a groove above the Piston, partially locking the Piston in the Bore (not applying the Clutch Pack very much).
Any thoughts on what would cause the fluid to blast out of the dipstick like that? I have 2 trans coolers and the temp didn't get over 180F. I have added about 8 quarts since startup.
All that being said, it was reading a quart low on the dipstick after running for a few minutes with the fluid temp around 105F. I calibrated the dipstick with "Full" being about 1/4" above the pan rail.
Frank@PerformaBuilt
Frank@PerformaBuilt
Frank@Performabuilt
Not sure if that would have anything to do with the slipping you are experiencing though. ?
You aren't by any chance overheating the fluid, are you? Do you have a transmission temperature guage?
I got the pressure transducer hooked up and want to do some tests.
What tests would be the most helpful in diagnosing this slipping?
Here is what ive got so far witht the fluid temp at 150F:
At Idle:
P - 75
R - 118
4 - 75
3 - 75
2 - 75
At 2000rpm:
P - 105
R - 185
4 - 125
3 - 125
2 - 125
