New electronics in older core?
Old Aug 12, 2023 | 07:49 PM
JaysSilveradoBuild's Avatar
Default New electronics in older core?
Hello. I've recently acquired a 2012 silverado with the 4L60E, I've got a spare trans (all neutrals), and a spare 2000 trans that works well. Wondering how hard/possible it'd be to a) put the electronics from the 12 trans into the 00 core, or b) put the internals from the 00 trans into the 12 core. I know they have different computers and whatnot but idk what's different beyond that. Any help appreciated
Old Aug 12, 2023 | 08:25 PM
Tranzman's Avatar
There are numerous changes made to the 2009 & up units compared to a 2000.
  1. addition of the ISS sensor
    1. Input shaft
    2. Stator shaft
  2. Internal mode switch
  3. removal of the Fluid Pressure Switch
  4. removal of the 3-2 control solenoid
  5. Vale body changes
  6. Case made some passage changes (I'm told)
So your best bet is to sell the 2000 unit and find a 2009 & newer unit or rebuild the old one
Old Aug 13, 2023 | 10:20 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Not really as stated something you can do while yes some parts will swap up most of the most important parts you need simply won't . I would just rebuild the 2012
__________________
Old Aug 16, 2023 | 11:31 AM
mrvedit's Avatar
Moderator
Yes, it will be much easier/cheaper to either rebuild you 2012 trans or get a 2009+. It also avoids the likely wear (out) of a 23 year old transmission. The missing ISS is the biggest issue.
Now going the other way, e.g. using a 2012 4L60E in a pre-2009 car is not as difficult. An earlier valve body and internal harness are the primary changes needed. But putting an early 4L60E is a 2009+ car requires an extensive rebuild.
Old Sep 17, 2023 | 01:06 AM
ronman60's Avatar
Default Putting a ‘09 in place of a ‘05
could you give me detailed instructions on that? I have a ‘05 yukon and an ‘09 4l60e that i have put in it and im at a loss as to how to rewire the plug or what else i need to do to make it function properly.
Old Sep 17, 2023 | 02:38 AM
vorteciroc's Avatar
A 2005 PCM can not control a 2009+ 4L60E.
2009+ Use an Internal Mode Switch instead of the traditional Fluid Pressure Switch Manifold + External Gear Selector Position and Neutral Safety Switch.
For Wiring/ Connector information for all Model Years, see the Thread in the HyperLink below:
LINK
Old Sep 17, 2023 | 11:47 AM
LS1Tech Sponsor
You would need to install a pre 2009 valvebody assembly, linkage shaft, internal harness assembly. No real wiring to do just swap all of that from earlier unit, But beware depending on what was wrong with previous unit you might be swapping the problems too
__________________
Old Sep 17, 2023 | 01:44 PM
ronman60's Avatar
would i need to remove the trans from the vehicle in order to do so? Or could those parts be changed while in the vehicle?
Old Sep 17, 2023 | 03:02 PM
LS1Tech Sponsor
They can be changed in vehicle just drop pan and do it ,
__________________
Old Sep 17, 2023 | 04:33 PM
vorteciroc's Avatar
Not all the 2009+ Cases have bosses for the NSS.
Old Sep 17, 2023 | 05:31 PM
LS1Tech Sponsor
Since he said was already in truck I assumed he has already mounted all the external stuff .
__________________
Old Sep 19, 2023 | 10:31 AM
ronman60's Avatar
Thats correct. I have already installed everything.
Old Sep 19, 2023 | 05:05 PM
mrvedit's Avatar
Moderator
I would suggest a 2003-2006 valve body from ebay ($120), a brand new internal harness ($40) and manifold pressure switch ($30). As Frank said, it can all be installed from under the car with only removing the trans pan. Oh, and get a new filter while you are at it. Likely will take 8 or 9 quarts of fluid to refill it.
Old Sep 19, 2023 | 05:38 PM
vorteciroc's Avatar
Changing the Selector-Shaft (and Seal) and Linkage here will be crucial in the Conversion.
