Stall advice BTR stage 3
Old Aug 29, 2023 | 04:59 PM
Bervinz28's Avatar
Default Stall advice BTR stage 3
Hello, first post here so apologies if it's in the wrong section or has been answered before. Tried the search tool but didn't find anything.
Gonna be running a 6.0 LQ4 with TEA stage 2.5 heads and a BTR stage 3. Swapping from a buddies 6 speed car to my auto. Ran great in his 98 SS car. Mines an 01 Z28. 3.42 rear. Full weight car. If I post this right I'll include a photo of the cam card. But long story short, what's a ideal stall to run with this setup?
Old Aug 29, 2023 | 05:15 PM
Tommy42088's Avatar
Simple solution man call one of the better companies who make stall converters and tell them your setup and they will get you right. You will have a thousand different opinions on here
Old Aug 29, 2023 | 05:18 PM
Bervinz28's Avatar
Appreciate it, will do.
Old Aug 29, 2023 | 05:41 PM
98CayenneT/A's Avatar
Old Aug 30, 2023 | 06:56 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
^^^ agree, 3600 absolute minimum. Contact Yank and FTI.
Old Aug 30, 2023 | 09:12 AM
Kingc8r's Avatar
Agreed on the minimum but honestly 4000+ is the better route. My SS3600 left a lot to be desired when I had a cam similar in size to the BTR3.
4-4400 would be what I’d go with. Gears will help it feel tighter too if the OP doesn’t have them already.
Old Aug 30, 2023 | 11:00 AM
The reason I posted 3600 absolute minimum is because many 'newbies' to the torque convertor stall realm are terrified/frightened of high stall numbers. Yes, 4000-4400 would be optimal.
Old Sep 4, 2023 | 08:39 PM
gametech's Avatar
Active Streak: 60 Days
Datalogs, or better yet, a dyno run graph would show where the torque comes in on this motor and make this a very easy decision. Especially since it was in a 6 speed car. Do you have access to any such data?
Old Oct 26, 2023 | 03:48 AM
Kingc8r's Avatar
I put a SS3600 into my Z28, I regretted it and bought a 4200 to replace it haha
Old Oct 26, 2023 | 11:08 PM
Dian's Avatar
are these recommendations for drag racing or normal driving? and how do you guys get such a car through inspection if it stalls at 4000+? or do such converters behave "normally" on the street and only stall that high when you feed them full torque?
Old Oct 26, 2023 | 11:21 PM
Kingc8r's Avatar
Gears help them feel tighter. Some states have easier inspections than others. Mine was a DD with the 3600 and I had 3.73 gears.
