whats the most reliable tranny(a4) for 700+rwhp?
Old 07-27-2004, 07:19 PM
blackz93's Avatar
Default whats the most reliable tranny(a4) for 700+rwhp?
prolly gonna go with a 200r4, but just weighing the other options.
Old 07-27-2004, 07:23 PM
kickassT/A's Avatar
that would be my suggestion, unless you did a 4l80e
Old 07-27-2004, 09:24 PM
Jammer's Avatar
Just a note: Carl Rossler ranked the 200 as the weakest based on size and strength of the internals (shaft diameters etc). He explained the 200, then 700 / 4l60 350 4l80 / 400 was how he rates them strength wise. His comment that hit home with me was " You hear so much about "bullet proof" 200's and lotsa shops advertise them... but its not often you see a serious consistant car at the track with one. In the end, I coud tink of a few, but many many more with 700s. Now there may be more aftermarket hard parts for the 2004r, that I dont know, just thowing my 2 cents in.
Old 07-27-2004, 09:43 PM
Zippinzee's Avatar
I believe it is just because the turbo buicks have been around longer so the 200 has had more r&d, given time they will figure how to modify the 4l60 to stand up to the LS1. I can rember when alot of the buick guys were going to the turbo 350 because the 200 would not cut it. If you truly drive your car much I am going to think you would really miss the overdrive.
Old 07-27-2004, 10:33 PM
kickassT/A's Avatar
give century transmission in richmond tx a call. his stuff is expensive, but supposed to be bullit proof.
Old 07-27-2004, 11:20 PM
James B.'s Avatar
The 4L80-E, guaranteed.
It's plenty stong, but the real marvel is how effortlessly it shifts under full throttle. They can be so precisely controlled that you can have silky smooth shifts with low throttle positions that ramp up to neck-snapping full throttle. The 4L60-E or 700R4 can be strengthened with better parts, but shifting is still being done by an over-worked band and undersized clutch pack. The 4L80-E (and TH400 for that matter) blow it away in terms of shifting torque.
When I set out on the 4L80-E swap I knew it would be better than the 4L60-E was, I did not, however, expect it to make the car so much more drivable - it's MUCH nicer than I had hoped.
Old 07-28-2004, 05:11 AM
1QUIKWS6's Avatar
So just what all needs to be done to convert to 4L80E? Is there a write-up or site that has any info?
TIA,
-Jay-
Old 07-30-2004, 02:34 PM
blackz93's Avatar
it just seems to do so well with all those turbo buicks...
Old 07-31-2004, 02:00 AM
houseofboost's Avatar
Where can I find more info on swapping in a 4L80e as well as anything else a person has to do to go along with it?
Old 08-03-2004, 09:52 PM
Jammer's Avatar
Sorry mods... there is a beautiful write up including pics on another site of installing a 4l80 in a f-body). PM me if you want to know where (not one of the other LSX sites)
Old 08-05-2004, 03:05 AM
jjnitrox's Avatar
Can you tell me where is this site? I AM DOING THIS TRANNY SWAP SOON.
Old 08-08-2004, 11:31 PM
Jammer's Avatar
Okay...55 PMs on this...go to Camaroz28.com, do a search..
Old 08-09-2004, 09:34 AM
Colonel's Avatar
Question
Jammer, I'd like to see Rossler's writeup on the strengths of the different trannys. Is that on the net somewhere?
Quick Reply: whats the most reliable tranny(a4) for 700+rwhp?
