Issues getting a 4L65e back together
Old Jan 27, 2025 | 01:49 PM
  #41
JimLev's Avatar
Thanks again Frank, just picked up the springs.
So what should I shoot for clearance? I’ve got a number of different size steels.
Is the GM spec of 0.060 to 0.085 too loose or should it be around 0.040?
Original springs on the right side for comparison.
Old Jan 27, 2025 | 02:57 PM
  #42
2BFAST's Avatar
Originally Posted by JimLev
Should it be around 0.040?
This ^
Old Jan 27, 2025 | 05:08 PM
  #43
bbond105's Avatar
Yes. 3-4 clutch clearance should be around .030 to .040 with .060 to .070 on your 2-4 servo travel. These clearances are important for the 2-3 shift timing. The 3-4 clutch clearance will open up once the clutch is applied a few times when the trans is in operation.
Old Jan 28, 2025 | 02:08 PM
  #44
FranksCustomTrans's Avatar
LS1Tech Sponsor
Note those springs are considerably stiffer than factory, Be sure you check your clearance dry WITH THE SPRINGS INSTALLED. They do make a difference trust me .
__________________
Old Feb 2, 2025 | 03:31 PM
  #45
NZLS1's Avatar
Is their any down side to using these taller stiffer springs in a car that won't see much high rpm, such as a longer shift time between the 2/3 shift due to a little bit more clutch slip? Or will it make no noticeable difference.
Old Feb 3, 2025 | 05:26 PM
  #46
LS1Tech Sponsor
No noted difference , I mean they really don't end up much stiffer when using a taller clutch pack .
I use them in all my builds always have since I discovered them. Readily available , Cheap and snap right into the holder.
But they really like the stock springs do play a part when you are working out clearances. I have stacked sets only to fine i was just a little tight for my taste, Put those in and was perfect.
__________________
Old Feb 5, 2025 | 07:14 AM
  #47
mrvedit's Avatar
Moderator
IMHO the springs will release the 3/4 clutch faster, during e.g. a 3/4 to 2nd gear downshift, reducing any dragging. I forgot the exact values from an ancient post of mine, but I calculated, that the springs reduce the clamping force on the 3/4 clutch by at most 5%. Keep in mind that GM decided to add these springs at additional cost and complexity; I assume they determined that a better 3/4 clutch release was worth the tiny reduction in clamping force. The Sonnax Smart-Tech input drum, which can hold up to 9 frictions, comes with longer springs to serve the same purpose.
Again, just my opinion.
Old Feb 6, 2025 | 11:22 PM
  #48
JimLev's Avatar
Originally Posted by 2BFAST
Yeah I hear ya. If thats the case, and the 3/4 clutch was smoked before you go back together with it you might want to find the cause of why the 3/4 clutch was smoked.
I never replied to this. The 3/4 piston looked a little loose. It didn’t fall off by itself if you held the whole stack vertically.
I replaced it, the overrun piston, and the forward clutch piston with Alto parts.
I air checked it, works OK, no leaks.
Old Feb 7, 2025 | 12:51 PM
  #49
LS1Tech Sponsor
FOR THE 3-4 MUST CHECKS- ENCAPSULATED CHECK BALL SEALING- FWD ABUSE PLUG- RELIEF BALL IN DRUM SEALING-NO GROOVES AT ALL IN STATOR-SHAFT RINGS-DRUM OF COURSE-LEAKS AT BAND PIN IN CASE AND LEAKS THROUGH 2ND SERVO.
The leaks at band pin area often overlooked and I have found can be pretty severe. You can check them by applying air through the case at 4th feed . You should hear nothing and certainly feel no air exiting the 3rd accum area in case.
__________________
Old Feb 11, 2025 | 02:21 PM
  #50
JimLev's Avatar
Frank, another rookie question. Where is the 4th feed?
Everything else checks out OK.
Old Feb 12, 2025 | 07:19 AM
  #51
2BFAST's Avatar
https://ls1tech.com/forums/automatic...e-build-8.html
Post #156
Old Feb 12, 2025 | 05:20 PM
  #52
LS1Tech Sponsor
https://ls1tech.com/forums/attachmen...ld-omhvj63.jpg
__________________
Old Apr 15, 2025 | 12:31 PM
  #53
JimLev's Avatar
Finally got back to putting the transmission back together.
Pretty sure the input drum is all the way down.
I’m not 100% sure the reverse input drum is all the way down.
I’ve shaken and turned it, this is all I can get it to drop.
Does it look like it needs to go down more or am I OK?
Old Apr 15, 2025 | 02:00 PM
  #54
LS1Tech Sponsor
if you can lift the input drum about 1/4 INCH OR REALLY AT ALL without raising the rev drum you are down.
__________________
Old Apr 15, 2025 | 03:37 PM
  #55
JimLev's Avatar
Thanks Frank. I could only lift it up about 1/8” so I’m good.
Appreciate all the help from all you guys.
Just got the pump and new filter in. Only need to put the pan and bellhousing on.
Old Apr 16, 2025 | 07:41 AM
  #56
2BFAST's Avatar
Looks good to me. If you shine your light on the sides of the drum you can see if the reverse drum is splined to the sunshell. You will know if you are or arent, but from that pic it does look like it. To me, when the input drum is fully splined it has a different feel to it. Hard to explain....
Old Apr 16, 2025 | 09:45 AM
  #57
LS1Tech Sponsor
YES the only thing we can teach "THE FEEL" which I find is an amazingly intuitive and functional tool lol. I can not count how many times I have uttered the words, "That just doesn't feel right " "That just don't sound quite right" lol.
__________________
Old Apr 16, 2025 | 10:42 AM
  #58
JimLev's Avatar
Yes, I could see the tabs on the drum were fitting into the sunshell.
Looking in thru the fluid filter hole I could see I have clearance from the top of the drum to the pump.
