4L80 and higher RPM questions
I'm looking for some input, on a couple of things about a 80E and RPM shifts.
First, I'm curious about the factory drum in these and how much RPM these are safe to spin/shift at?
I have heard a few different things on this.
My other question is on the speedo sensor. Recently upped the shift rpm and it wiped out the speedo sensor. I know these are pretty close in tolerance and I imagine the extra rpm either lost a little fluid film on the bushing or maybe it just lost tolerance. Curious if anyone else has this issue?
First time I've had this happen on a 80E, but I definitely wiped out a few sensors in 60's in the past.
If all the bushing are snug and on particular all in the rear planets , case, tail . You could not see an issue with the sensors being killed.
I agree with Frank.
However there are three options as far as I am concerned.
I need to remember/ determine the manufacturers of these drums, and would need to know what type of valve-body is being used.
Stock valve-body: go with a 36-Element iron drum (some use stock dimension Intermediate Frictions, some use Ford C6 Frictions) and you keep the Overrun Band for manual 2nd-Gear.
Aftermarket/ modified valve-body that does not retain the overrun band for second gear: go with a 34-Element half aluminum and half steel drum. it is an aluminum drum with a steel center to spline to the Sun Gear Shaft and for the Teflon sealing rings.
The third and most expensive option would be the above drum but with a 36-Element Sprag instead of 34.
-Chello III
-Chello III
I appreciate your response. I wasn't sure about the drum needing changed, but I had kinda heard that.
This particular transmission, I didn't build, so I don't know for sure if the bushings were changed or not when it was gone through, but I don't think it's coincidence that I had just changed the shift rpm up to 7200 on this particular car, and now, it's shifting a little weird like it tagged the sensor. Pull it out this week, I'm expecting to see a little love mark.
continuing the discussion, are there any downsides to using an aluminum direct drum? i have read somewhere about loosing 2nd gear engine braking, but that's not a huge deal for most of us.
can a 4L80e with aluminum drum still be a streetable transmission that lasts for 30-50k miles, or is it kind of a track only deal at that point?
i certainly would not suggest it if you were actually planning to use manual 2nd for braking to any extent.
is there a preferred vendor for the aluminum drums? what would be the pros/cons of the different offerings?
just from a basic search i've found coan, CK, suncoast? and looks like maybe jake's has one although it wasnt clear to me if they are making it in house or buying one
For higher RPM, you need a built transmission with a billet drum and better pump to prevent fluid starvation. The sensor failure is a classic sign you're exceeding the stock fluiding limits.
It is a Mass/ Inertia problem...
You could think of it as a Centrifugal problem, where a given Mass must be accelerated and decelerated without loss of control/ or coming apart.
The lower the Mass/ resulting forces, the less work required to keep said given control.
@truckdoug has been working on some R&D for his own really killer set-up for a High RPM 4L80E project!
Check out his YouTube Videos!!!
thanks. holy crap, i was not expecting to watch mads mikkelsen building transmissions today but here we go
@truckdoug do you have any suggestions for which videos to watch regarding high RPM and 4L80e specifically?
i did find this one about the 36 element sprag, was very informative -
First the wear and tear on them is terrible.
The splines where the Drum engages the Sun-Gear Shaft strip-out...
The Bore that is a sealing surface for the Teflon Sealing Rings on the Center Support get grooves and stop sealing...
The Lugs inside the Drum where the Steel Plates of the Clutch Stack are start to both groove and round-over/ strip-out...
And if you have an Intermediate Overrun Band, the Band surface of the Drum wears away!
All that Debris goes into the Fluid!
And if you have a high-flow Filter for a Trans-Brake... none of that debris gets caught by the Filter!
Some of this can be minimized with a Hard Anodized half Steel, half Aluminum Drum.
The all Aluminum and Non-Anodized are the WORST!
There are definitely negatives to using an Aluminum Direct Drum.
also, how do you feel about the billet steel drums with 36 element sprag for high RPM shifts ( say, 7500 rpm )
Thanks
Yes, a billet steel drums with 36 element sprag can work in that application as long as power is not super high.
There are also billet steel drums that have been lightened and work great!
