tranny goes from 1 to 4 sometimes???
Old Aug 14, 2004 | 02:05 PM
B18B1LS1's Avatar
Default tranny goes from 1 to 4 sometimes???
Last night at the track my tranny went straight from winding out first into OD and then just stayed there until 60 and then locked the converter! This was at WOT on a stalled but otherwise stock 4L60E. It only seems to do it after it has been sitting awhile, if I had hot lapped it back around again it would have been fine. Any ideas? It really sucks to wait in staging just to run 15 second 1/4's! Thanks.
Jeffrey
Old Aug 14, 2004 | 02:39 PM
Cerebrex's Avatar
check your line pressure and make sure your fluid level is good.
Old Aug 15, 2004 | 06:25 PM
B18B1LS1's Avatar
Both are good. The line pressure is near stock, via HP anyway. And the fluid level is right where it should be. I logged the runs on my HP and couldn't find anything out of the ordinary. Any other ideas? Anyone?
Old Aug 16, 2004 | 02:38 AM
BADFNZ's Avatar
That's just the skip shift bro
But in all seriousness, I've never heard of this happening so keep us posted.
Old Aug 16, 2004 | 08:59 PM
B18B1LS1's Avatar
Oh well, I guess I have a powerglide from time to time!
Old Aug 17, 2004 | 01:21 AM
BADFNZ's Avatar
With one hell of a bog I'm sure!
Old Aug 17, 2004 | 03:28 PM
Evil 99's Avatar
Default have herd of this problem
It has been my experience that a 1-4 upshift is caused by a defective shift solenoid B in the trans. the shift solenoids are both the same and relatively cheap from the dealer.
Old Aug 17, 2004 | 09:13 PM
B18B1LS1's Avatar
Would a bad solenoid throw a code? So far I've had nothing. But if they are cheap maybe it's worth a try.
Old Aug 18, 2004 | 12:04 PM
Evil 99's Avatar
It would only set a code if the electrical part of the solenoid was at fault.
