Th350 behind 6.0
Old Nov 27, 2004 | 08:10 PM
Zedzag's Avatar
Default Th350 behind 6.0
Will my th350 bolt up to a 6.0 bellhousing and flexplate? I did a search bit I couldn't get a for sure or not.
Old Nov 27, 2004 | 08:36 PM
White98Z's Avatar
Yes it will you will be loosing a a couple of bolts but it will work.
Old Nov 28, 2004 | 04:51 PM
Zedzag's Avatar
how about the flexplate?
Old Nov 29, 2004 | 12:00 PM
Smoke T/A's Avatar
You will need a 98 flex plate.
Old Nov 29, 2004 | 08:40 PM
Zedzag's Avatar
Is that a 98 fbody or truck converter or are they both the same? Anyone have a part number? I get too many different opinions.
Old Nov 29, 2004 | 09:46 PM
Zedzag's Avatar
A little more research confirms its the f-body one.
Old Nov 29, 2004 | 10:23 PM
White98Z's Avatar
Yes you will just need to get the th350 98 flywheel and a converter with built for a 6.0 with ath350 so that the nose on the converter is the correct lengeth
Old Nov 30, 2004 | 12:29 AM
Zedzag's Avatar
I already have a th350 and a TC from a old style 350 that I want to use. Street and Performance confirms that I need flexplate#12551367 but they don't mention a "special" connverter.
