A4 bogs after 1-2 and 2-3 shift after vig2800 and TransGo shift kit installation.
Moderator
I had the Vig 2800 installed first and noticed a little bog but after the shift kit installation it is more noticeable. The 1-2 shifts are much worse than the 2-3 shifts. This only happens at WOT.
Any suggestions as to what is causing this?
Mods: Ported MAF ends. MAFT, !EGR, MTI lid and pulley, Free mods.
Re: A4 bogs after 1-2 and 2-3 shift after vig2800 and TransGo shift kit installation.
What year? Sounds like the dreaded Torque Management issue I have.
https://ls1tech.com/ubb/cgi-bin/ulti...c&f=2&t=000008
<img src="images/icons/smile.gif" border="0">
LS1Tech Administrator
Received 1,806 Likes
Yep, if it's an '01 or up you're almost certain to have TM issues with a shift kit.
It's rare with a pre '01 though...
My car does that same crap....of course i also have 2.73 gears <img src="images/icons/confused.gif" border="0"> now i just take it up to about 6300 before i shift and that has help quite a bit.
Wheels up Director
If it is TM I know at least 1 guy around here that doesn't have a 01, Either got a 99-00 with a vig3200 and transgo that was a dog but he got rid of TM. Once he got that problem corrected he gained at least a couple tenths
<img src="images/icons/grin.gif" border="0">
Can't say that i've ever gotten the bog you've described. The car hits hard and the shifts are quick and precise. Must be some truth to the TM. <img src="images/icons/confused.gif" border="0">
Moderator
Thanks for the replies. The car is a 98 Z28 with 3.23 gears. The 1-2 shift is great but the 2-3 could be a little harder but is still a big improvment over what it was.
LS1Tech Co-Founder
Could be that your shift points need to be a little higher if you dropping below the meat of your powerband.
Autotap would tell you a lot. Just make sure you find some good open road and log multiple runs. Before adjusting my shift points I was shifting way too soon. Now with the +6 adjustment i'm right where I wanna be. <img src="images/icons/smile.gif" border="0"> I have the 273s so I can get more outta the gears. <img src="images/icons/smile.gif" border="0">
Moderator
I autotaped the car tonight and found that just after the 1-2 shift I get -5.5* timing advance. On the 2-3 shift there was -3* timing. On this run the 1-2 shift took place at 5485 rpm and the 2-3 shift was at 6024rpm. On previous runs the 1-2 shift was at 5700rpm.
In autotap under the transmission section what is TCC Apply?
How long did that negative timing last for? Should only be a split second.
[quote]Originally posted by RPM WS6:
<strong>How long did that negative timing last for? Should only be a split second.</strong><hr></blockquote>
On mine, exactley. It would go from @22* down to 2* and the back up in the @20* range. <img src="images/icons/smile.gif" border="0">
Moderator
Windy City 02Z- Thanks. Is there an Auto reading that shows the application of Torque Management?
RPM WS6- It lasts long enough for the car to nose dive on the 1-2 shift. The 2-3 shift is not as bad.
Goto http://members.aol.com/jnorris404 and download any of the “timing” files to see the autotap readings.
I read the .xls file and I see what you mean. -x* of timing can't be good.
What I'd like to see is a log of Throttle Position, Current Gear, RPM, Timing Advance and Knock Retard. This way we can confirm that it is only between shifts and make sure that there's no chance ASR (If your car is equipped) is kicking in because the shift kit is possibly causing your tires to spin a little?? Just an idea. <img src="images/icons/smile.gif" border="0">
Moderator
Goto http://members.aol.com/jnorris404 and down load any of the fri4 files to see the complete autotap file of the run.
The car does not have ASR. I am running ET Streets. I do not have traction problems.
John
12.6 @ 106. 1.7 60'
[ November 19, 2001: Message edited by: JNorris ]
[ November 19, 2001: Message edited by: JNorris ]</p>
John
12.6 @ 106. 1.7 60'
Moderator
[quote]Originally posted by ShooterSS:
<strong>You are almost identical to me. I have a Vig3200, Transgo and Cooler. All my shifts, 1-2, 2-3 and 3-4 drop off significantly. I guess it was like that before the install but I'm thinking I didn't notice it without the shift kit. A reprogram is all I can think of. <img src="images/icons/frown.gif" border="0"> </strong><hr></blockquote>
What do you mean "All my shifts, 1-2, 2-3 and 3-4 drop off significantly"
John
John
Moderator
What criteria does the PCM use to know when and how much torque management to use?
I have some runs when there is no torque management issue and then the very next run I will have negative timing values before/after the shifts.
Thanks
John
Thanks
John
I mean right between them.
IE: From 1st to 2nd, my timing goes from @35* timing - to 2* - back to @30* at 40% throttle.
On the 2-3 shift and the 3-4 shift my timing drops about 10* each time.
Not as extreme as yours but very noticable. <img src="images/icons/smile.gif" border="0">
