has this worked for anyone.
Old Mar 13, 2005 | 03:38 PM
Ryan1985's Avatar
Default has this worked for anyone.
I have a bad vib. from the converter. TCI tells me to turn it one whole over. I just cant see that fixing anything because i thought the converters are suppose to be ballenced. right? Just wondering if anyone has had luck in this working. If not im gonna just put the stock one back in and sell my TCI for a better converter.
Old Mar 13, 2005 | 05:05 PM
RevGTO's Avatar
Pontiacerator
It has worked for some guys - you can search and maybe find some of their accounts. What kind of vibration are you experiencing since installing your TCI?
Old Mar 13, 2005 | 05:19 PM
jimmyblue's Avatar
Moderator
Late F-body flexplates have been known to crack. The early ones
are better built. I got a '98 virgin flexplate for my converter install.
The converter -should- be balanced, but there's always a chance
that the converter and/or flexplate mount-points are not exactly
true to center and rotating them may make a more fortunate
alignment of the planets. Or something.
But if you can, check and be sure you don't have a damaged
flexplate.
Old Mar 13, 2005 | 09:58 PM
Ryan1985's Avatar
well its an 02. and the vib. doesnt start untill 2100 rpms.
Old Mar 14, 2005 | 02:46 PM
Ryan1985's Avatar
anyone else.
Old Mar 14, 2005 | 08:17 PM
chrs1313's Avatar
had a vibration in mine when i first put it in ,about the same rpm. unbolted it from the flex plate and turned it 1 bolt hole, and the vibration went away,i did not want too try it either, thinking the same as you,it should be balanced but it worked!!
Old Mar 14, 2005 | 08:19 PM
Ryan1985's Avatar
allright thats good to hear. I guess ill try it out this weekend and see if it works. Its just a PIA to do but oh well if it works ill be happy.
Old Mar 14, 2005 | 09:29 PM
OVRPWRD's Avatar
Let us know what the outcome
