YANK's NEW PRODUCT LS/1 400 transmission
Old 04-05-2005, 05:14 PM
Yank's Avatar
Default YANK's NEW PRODUCT LS/1 400 transmission FIRST LOOK!!
YANK is always looking to improve the LS-1 line, and now we have done it again:
Yank has taken the th400 and reworked the weak belhousing area and given back the structure that is lost when you install a th400 to the ls-1 block
when you install a th400 to the ls1 engine you loose the bolting together of the belhousing to the oil pan, this is important as the center line of the enging and the stock th400 transmission will flex under load and cause a misalignment.
This will damage the transmission front pump and cause uneven wear on the converter hub and leaking (under high load as transbrake use)
Yank have tested this and found that transmission life is extended as the input shaft is kept in alignment to the engine is allows
your clutch packs to lockup on center!
NOTE: you can use any th400 transmission for this conversion.
There are 2 kits 1 is a lock-up and the other non lock-up
lock up kit includes:
A, custom front th400 pump with lock-up control valve body (shown)
B, billet input shaft - to handle high power levels
C, belhousing adaptor fits stock 4L60-E belhousing
D, Converter Lock-up any stall speed
F, complete instructions
Non lock-up kit
A, custom th400 pump with 4L60-E adaptor installed
B, Converter your choice of stall speed
C, instructions
Call us for details and pricing will be posted soon
Thank's for looking
and any input is welcome
Old 04-06-2005, 05:21 AM
GTS346's Avatar
I'm speechless, WOW that is a nice piece of engineering.
Any plans for TH350 Case?
Are you selling bare cases? If so how much $$
How come you guys put the extra bolt hole on the passenger side when the LS1 doesnt have a bolt there? (the one in between the top middle and the side middle)
Old 04-06-2005, 05:54 AM
BRracing's Avatar
Default Ls1/th400
Non lock-up kit
C, instructions
Thank's for looking
I'm waiting for mine, I can assure you we will test it to the extreme!
I would presume that the bell is not SFI rated?
Thanks,
Buster/BRracing
Old 04-06-2005, 09:58 AM
S_J_H's Avatar
looks like you used a stock ls1 4l60e bellhousing with an adapter plate between the case and bellhousing.
Good idea. Might want to just sell the adapter plate for all the guys who already have a th400 installed and may want a stronger setup.
Steve
Old 04-06-2005, 11:33 AM
Yank's Avatar
Steve
Yes, you use your belhousing and modifly your trans
we are selling the kits only
not the transmission you do it yourself with parts supplied
so you can use trans with a broken belhousing or one from another car line like a Buick or Pontiac
Old 04-06-2005, 11:50 AM
CamaroCain's Avatar
It looks like they are using the stock 4L60e bellhousing that already has that bolt hole.
Looks like a great piece YANK, keep up the good work!
Old 04-06-2005, 09:27 PM
BORN2LOSE's Avatar
How much are these? And what kind of HP do they support?
Old 04-07-2005, 08:07 PM
WILWAXU's Avatar
Slick setup Mike!
Good work!
Old 04-07-2005, 09:12 PM
PRAY HRD's Avatar
definately looks tight! nice work there.
Old 04-09-2005, 08:27 AM
7 Second Club
ty_ty13's Avatar
I need one for a th350 now
Tyler
Old 05-30-2005, 06:43 PM
Yank's Avatar
These kits are shipping at this time!
Pm or e-mail for pricing info mike@converter.cc
Thanks
Old 05-30-2005, 07:09 PM
Z06PSI's Avatar
TH350 kits...????????
Old 05-31-2005, 09:21 AM
Yank's Avatar
we have the crossmember kits
http://www.converter.cc/drivetrain.htm
but do not sell any 350 transmissions
as we like the th400 better
Old 05-31-2005, 12:30 PM
oOoLy's Avatar
Wow... that nice kit .. i will order one for my car soon but what kind of HP do they support?
Old 05-31-2005, 01:16 PM
firechicken2k's Avatar
i'm interested as well
please give the rwhp #s also, not flywheel
Old 05-31-2005, 01:49 PM
Yank's Avatar
The transmission is custom built for the customer's needs as to power level
and price will adjust to parts needed for your setup
or you can adpt. your th400 to this kit
Old 08-06-2005, 03:42 PM
Yank's Avatar
we now have many models in stock that can ship today!
with or without transbrakes, auto or man. valvebodys also a selection of gear ratios and in lockup of non lock up styles
call us 479 632 6355 Mike mike@converter.cc
Old 09-18-2005, 03:56 PM
Yank's Avatar
Product Update
Yank has also just introduced a special kit to allow the use of Your stock or replacement 4L60-E drive shaft!
You will not have to replace your carbon fiber or special drive shaft when this kit is orderd or installed with one on our TH400 units
Features of this exclusive Yank item are:
Custom output shaft in the 4L60-E spline
Reworked extention housing so the TH400 is overall the same as the 4L60-E
also included special high RPM seal, and rear bushing with increased oiling
Old 09-18-2005, 04:04 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
great job guys
Old 09-20-2005, 12:14 PM
Ragtop 99's Avatar
Neat. How much HP will the adaptar hold?
Quick Reply: YANK's NEW PRODUCT LS/1 400 transmission
