Tranny Cooler Install Help
Thanks so much
on the A/C condenser / radiator stack. It was the biggest
Hayden that Pep Boys had on the rack. I routed the soft
lines through a little rectangular cutout that is by the
bottom corner of the radiator. I used slit pieces of vacuum
hose to keep the sheet metal edge from chafing the hose
for the cooler. I put my cooler in the hot line before the
radiator though most folks seem to go the other way.
If I were going to do it again I think I'd put it in the hollow
space between condenser and radiator. Though that would
rob effectiveness some, when the A/C is on.
who makes that cooler?
