Manually shifting an A4
Old Dec 26, 2001 | 01:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Manually shifting an A4
The lag can be huge.
Make sure the rev limiter is where you need it.
I have had mixed success manually shifting my car.
You can manually upshift a 4L60E and wind out a shift point, but IMO you can't really shortshift
consistently.
But when I have had shift points that were too low I have manually shifted.
I tried doing that at the track last time and I hit the rev limiter on both shifts unfortunately. So I went 11.15@120.30 with it shifting on it's own and then 11.25@120.99 hitting the rev on 1-2 and 2-3 so clearly higher shift points will help my car run 10's.
Old Dec 26, 2001 | 01:34 PM
Terry Burger's Avatar
I was thinking of putting in a shift lite and then setting that to help me with the lag.
I am shifting to 2nd around 6400rpm and 3rd around 6600rpm. I have a 7000rpm rev limiter, so I'd like to try shifting around 6800-6900rpm for both shifts to see what happens. So if I always move the shifter at 5000rpm will the car always shift at say 6200rpm?
Old Dec 26, 2001 | 02:25 PM
LS1Tech Co-Founder
You'll have to experiment, I always tried to have the shiftlite/tach come on at least 200 rpms before I actually wanted to shift.
Old Dec 26, 2001 | 04:54 PM
WILWAXU's Avatar
Been there, try that, moved on <img src="gr_grin.gif" border="0">
I've never been able to get a better pass by shifting it myself, normally it hits the limiter.. no matter how fast you upshift it.
Old Dec 26, 2001 | 05:50 PM
Jackyl_30's Avatar
I never maully shift my A4. The computer can do it a lot better than you can. Plus manually shifting a A4 is not good on the tranny.
Old Dec 26, 2001 | 06:58 PM
SCZ28's Avatar
Quit being so cheap Terry. <img src="gr_grin.gif" border="0"> YOu can buy and resell a HPP for the same price.
Old Dec 27, 2001 | 12:47 AM
Default Manually shifting an A4
I want to try out some different shift points at the track, but I am too cheap to buy a HPP. What is the lag time between when you shift an A4 and when the tranny actually shifts? Is it consistent? Also does manually shifting have any impact on the TM?
Old Dec 27, 2001 | 07:37 AM
99BlueZ28's Avatar
Just do yourself a favor and buy the PP3. I mean look at all the money you've alraedy put into the car. You can get a used one for a couple hundred dollars. Worth it IMO.
