Damn rock-on transmission ;)
What kind of 60fts do you pull? I know my old Yank ST3500 was the hardest hitting converter I'd ever experienced. It created traction issues. I swapped to a Yank PT4200 which is a bit more suitable for my current set up. Yank does make a great stall converter. Thanks for the tranny report!
http://www.speedworldmotorplex.com/calc.htm
Can you get the brake to work without a the troubles of backin up and all like I have read on th400 cars? Like the tranny will act normal unless the brake is activated? If so i will seriously be considering a tranny from yall.
Dave, I sent you a PM!
bmr tq arm
hal f/r shocks
air bag in right rear
Dave I tried dammit....ran another best today in the heat of 10.12 @ 137 on a 1.54 60'
It got 290 miles round trip on it today. This weekend I put 8 passes on it and 540 miles!!! I was lucky enuff to have my daughter tape all my runs....only to rewind the tape some and tape over my new best!!!
Who can complain though when it's your 13 yr old daughter taping you at the track and NEVER complaining about the 2.5 hour ride each way. FWIW- I ran my 10 bolt for a good while and ran multiple 10 second passes (not low 10s though)
I installed an Eaton Posi, kept the bullet proof 3.23 gears, solid pinion spacer, T/A cover and stud girdle and I welded the axle tubes to the housing. I also added LCA relocating brackets as well. This rear held up to 1.43 60fts and never made a peep. It was working great when I sold it and is still going.Kudos to ya Cablebandit and Rock-on.
1quickta......stock rear with a T/A performance cover.
Congrats on the 10.12....I wish we could have done it friday night....
...I'm calling you in a little while Jerry....
If I could leave like the stangs at the track, I'd be gettin it!!!
