Converter Install: Issues
Old Jun 28, 2005 | 11:31 AM
hardtopSS's Avatar
Default Converter Install: Issues
to those who have actually installed their converter.....any special tools/situations/techniques you have used???? looks straight forward, will be installing next weekend...
Old Jun 28, 2005 | 12:54 PM
rufretic's Avatar
I'm in the middle of mine right now. Just getting started really. I have the trans unhooked, its just held up by a jack. I'm going to start the drop wednesday and hopefully finish this weekend. I have to do it a little at a time because how much I work. I havn't got to the hard stuff yet but it shouldn't be too hard. Right now the only problem I have is the drive shaft seems to be stuck in the joint by the rear. I already took off the bolts but couldn't get it to slide out. I need to mess with it a little but didn't have time. I hope some people that have done it before will chime in to give us some advise/tips.
Old Jun 28, 2005 | 02:33 PM
blue2000Z28's Avatar
Not to steal the thread, but i would like the same info, and When you get your converter in let me know how it does, I have a vig 4000!!
Thanks
Old Jun 28, 2005 | 02:54 PM
formulajunky's Avatar
The only hard part is Unhooking the Converter from Flexplate. I used a flathead Swrew driver to hold the flexplate so i could brake lose the Bolts on the TC. Mine where lock tighted red so it takes some Time and effort. Over all an easy job. . Gl its kinda easy once you get done .
Old Jun 28, 2005 | 08:42 PM
rufretic's Avatar
"its kinda easy once you get done"
LOL, I feel that way about everything, its while your doing it that sucks.
Old Jun 30, 2005 | 09:32 AM
rufretic's Avatar
Well I got the trans out last night. Not to bad, the worst part was breaking it free from the block. It was stuck on there good and then when it came off I dropped it on my chest and spilled fluid all over myself(do not do it like this, use a tranny jack). Other than that its been easy so far. I should be able to finish it up saturday.
Old Jun 30, 2005 | 12:04 PM
Rod's Avatar
Rod
I would caution anybody who attempts this to be careful around the exhaust heat shield they are very sharp. I can tell you from experience
Old Jun 30, 2005 | 12:31 PM
josh99ta's Avatar
Sold The Fun Stuff :(
I feel bad for you man, that had to suck.
Its really a straight forward swap, just have some patience, because if you get frustrated it'll take you much longer. Unbolt the converter from the flexplate, using some type of wedge to hold the flexplate still. Getting the tranny off the engine can be a PAIN. Use a tranny jack and wiggle the tailshaft of the tranny until it pops loose. We had to use an air hammer on mine the first time. Prefill the converter with some tranny fluid just to get things lubed up so you're not dealing with a dry start. Make sure the new converter seats. My TCI was a PAIN to get seated, had to take it off and put it on numerous times, and we finally got everything lined up and it dropped right into place. Take your time and have some patience when you're bolting the converter back to the flexplate, it just takes time (and swivel extensions aren't a bad idea either, they'll help on bolting the converter to the flexplate as well as the bellhousing bolts). Just take your time and have some patience and it's all pretty straightforward.
Old Jun 30, 2005 | 01:36 PM
luvmeZ28's Avatar
could you guys post up a list of tools/sizes of sockets and things of that nature that would be needed?
i hope to be doing mine in about two weeks, and i want to make sure we have all the right tools wherever we end up doing it.
Old Jun 30, 2005 | 02:08 PM
GregWS6&z28's Avatar
there's an install document done by Modern Musclecars if you search. Thats the only document you need.
Old Jun 30, 2005 | 04:08 PM
luvmeZ28's Avatar
thanks
Old Jun 30, 2005 | 07:39 PM
rufretic's Avatar
I'll second that, I have a nice slash on my wrist. If it was any deeper I may have needed to go to the hospital.
"there's an install document done by Modern Musclecars if you search. Thats the only document you need."
Yep, thats what I'm using. Its very easy to follow, its just doing it that can be a little ruff.
