built 4l60E & TC problem need advice
the tuner uses ls1 edit at this point i'm ready to buy hp tuners for him! i don't know alot about tunning is hp better than ls1? no check engine light
Times are text book bty. 3-4 clutch has no signs of slipping....band is flawless. Found a tear in the valve body gasket area under the manual valve in a dead circuit. Run the car on the street with breakout box, perfect shifts never hitting the liminter. As far as buying another transmission lets do this ...bring your car up...I'll set up a manual valve body for this test, we'll take the tunning out of the picture and we'll see what happens....seems simple to me ...and willing to do it..oh lets set it up so you can take it to sanger to test it under wot...I don't like wot on the street...Just my 2 cents ...Frank anytime one of my units doesn't shift it's my problem. I've never had one that wouldn't shift and you'll not be the first. Hope this helps Dave
"breakout box" I would think it is pcm related. Can you email me your ls1edit file? I would be glad to take a look at it. cablebandit@charter.net Stick with Dave....his customer service is the best and you will get it figured out working with him. If the pcm isnt asking for a shift, well then you need a better tune. If it asks for it and it doesnt shift....Dave will get it right but I'd bet money it is a pcm issue if Dave had it on the tranny dyno.
i'll get the current tune & send it to cable bandit.
Thanks All
Send me the file and I'll check it out. Definitely learn to tune yourself. It will save you a lot of headaches. I understand your frustration....I felt the same way until I got my tune right and then BANG...tranny was shifting like a ****!!! I dunno but I would guess you have 3.73+ gears.
Dave i'll give you a call on monday & set up time to come to your place, thanks again
3.73 is when mine really went nuts....thats why i guessed that. Hopefully it will be something simple!! What brand and size tires are you running?
the speedshop guy probably went home after he sent the file it may be monday before he gets your reply
i really appreciate your help.
Dave knows how to build them. But it is better when you take the tuning out of the loop. By the way, if Chris R tuned it, it is locked.
Get HPtuners or have a shop with HPtuners help you out.
I purchased my own copy since I got burned by the locked tune issue.
