No 4th gear lock up
37 37 37 40 40 40 40 40 40 40 40 40 40 255 255 255 255
If you cruise around 45-50mph it locked up but once you hit highway speeds 60mph + it unlocks and stays unlocked. Have experminted with stock and modified lockup tables.
Problem should be solved though. A TPS code was present. P0121. It even prevented the car from being racable at the track. cleared the code and it locked up and shifted properly. Its a ported tb, I need to check the tps voltage and see whats causing the code.
edit: nope still not locking in 4th
