3.73's and a vig3200???
Old Jan 22, 2002 | 04:45 PM
Slow Z28's Avatar
Default 3.73's and a vig3200???
anyone have this combination? how do you like it for racing and normal street driving? what were your times? 60ft and 1/4? thanks a ton
Chris
Old Jan 22, 2002 | 05:27 PM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: 3.73's and a vig3200???
I think Trevor D has this combination and he is traction limited, even with ET Streets, LOL! That's a pretty hard launching combo.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 22, 2002 | 05:36 PM
Slow Z28's Avatar
[quote]Originally posted by Patrick G:
<strong>I think Trevor D has this combination and he is traction limited, even with ET Streets, LOL! That's a pretty hard launching combo.</strong><hr></blockquote>
that's what i'm hoping for <img src="gr_images/icons/wink.gif" border="0"> . and is it gonna help a lot from a roll???
Old Jan 22, 2002 | 08:07 PM
Matt98SS's Avatar
you staying with Nitrous chris? if not just get the 4.10s <img src="gr_images/icons/wink.gif" border="0"> and some ET drags
Old Jan 22, 2002 | 08:36 PM
StreetStalkerZ's Avatar
I have that combo along with Black Sunshine. It hits hard from a flash point and you better have some tires to take full advantage of this set up. I ran 10.5X15 ET Streets at 15psi hot along with RR airbag 18psi,Mac LCA and BMR LCA brackets to help aid the shock. I found that leaving the tree at 1100rpms got me my best 60fts.
Old Jan 22, 2002 | 08:47 PM
Slow Z28's Avatar
thanks for the advice!! tires that i have now(M&H Racemaster) will hopefully work a little bit since they are new and came with the pro stars i bought. otherwise i might get another set of e.t. streets to run. with the 3.73's and the nitrous i'd be running a 28" tall tire
matt- i sold my tnt wet kit cause i've run into a little financial problem(got layed off), soi'm just looking for little stuff since us WI guys have a dealer tech that does perfect gear installs for VERY cheap as a side thing. anyways, i thought about the 4.10's, but i'll probably get a TNT dry kit and hide it for the street racing.
Old Jan 23, 2002 | 02:28 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Like Patrick said, I'm running the combo, and I love it. Like he said, be prepared to need some slicks to get it to hook up. It hits HARD off of the line! My best ET is in my sig, and it was spinning pretty bad. My 60' times should be somewhere around 1.60. I should find out on Feb. 2nd. I have a set of Hoosiers on the way, and that should cure the no traction issue. <img src="gr_stretch.gif" border="0"> Even though I haven't been able to completely hook the car up since the 3.73's went in, it feels GREAT down the track. The shifts occur much quicker, as expected, and I'm crossing the line right at 5,600-5,700 RPM on 26x11.5x16" ET Streets. The RPM's drop to right at 5,000 RPM on the shifts. I did Ed Wright's custom tuning at the same time that I swapped gears, and I've gained right around 2 MPH in the 1/4 with these two mods. Having my shift points at 6,200 and deleting torque mgt. helped out just a hair, too. <img src="gr_images/icons/wink.gif" border="0"> I hope to see an 11-second timeslip w/ the new Convo Pro/Hoosier setup. It will also shed some nice weight off of the car. I've been run my 17's on the front, and the ET Streets are mounted on stock Z28 rims WITH tubes! <img src="gr_eek2.gif" border="0">
[ January 23, 2002: Message edited by: Trevor D ]</p>
__________________
Old Jan 23, 2002 | 02:44 PM
Slow Z28's Avatar
Sweet!!!! Thanks trevor. i was about to bump this up to the top to see if you'd respond. well, it looks as if this will be one of the next things in line for my mod list. thanks guy.
Chris
Old Jan 23, 2002 | 08:29 PM
I'm glad I could help. Let me know how it turns out!
__________________
