4L60E Upgrade advice (rebuild time)
Well my 12.1447 Nitrous launches took their toll on the stock tranny and it's shifting funny from 1st to 2nd (Waits till 3500RPM
So it's time to pull the biartch and throw some money at it.
I'm planning on spending about 1k in parts. I have a guy in San Antonio that will rebuild it for me.
I already have a Vigilante 3200 in it, and a tranny cooler, and temp guage so I should be covered there. I draine dthe fluid and there were some small metal shavings (very minor, like 5 or 6, no longer than 1/4th inch and a little thicker than a hair. I was wondering what items y'all would reccomend I request upgraded/changed. I'm sure he has a list of things that shoudl be done but I'd like to know some other people's advice so I walk into this with open eyes and armed with information.
He insists that he can get any parts I want for 10% off list price.
I'm buying a tork arm relocation before the tranny goes back in.
I'm currently at 413/414 RWHP/TQ (on spray) and my long term plans are to have 400 to 450HP NA and be able to launch with a 100 to 150 shot out of the hole.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
does your convertor come with anti-baloon plates for use with the nitrous?? if not u might want to consider that? im not really familiar with the vig stall convertors i still have the old school 700R4 that i built
Honestly, I'm not positive if the stall has "anti-baloon plates" That's something someone has brought up before, but I don't know how to check, and the TC is a "level 1" which is made by Vigilante, but sold under another name. I came by the stall second hand and for a mere $350.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I am going through the same situation as you right now besides my tranny isn't blown yet.. but i know its life is coming to an end.. I know a good guy that can build a trans for me so i think i am just going to go on Speed inc's site or another site and get the list of parts they use to build a stage 2 or 3 4L60E.. and just give him a list and let him do it from there..
But how long to built 4L60E's last? and how much power can they really hold?
Someone help us out! give us some info on built 4L60E's!! Let me know if you learn anything Ouija!! cya
From looking at speed Inc and FinishLine Performance it looks like the typical Level 2 trannies can handle up to about 450HP/400TQ. Level 3 can handle upwards of 600HP/550TQ and level 4's supposedly can handle upwards of 850HP/800TQ respectively.
Seems to me that most places have a variance of about $1000 between a 4L60e and a Level 4 4L60e. None of them list a Torque Converter change, that's an additional charge.
The Evil Series (I'm assuming is a level 2, 3 & 4)
Street Evil Includes:
Bushing Kit
Master Overhaul Kit
New OEM Style Filter
Update SKF Input Sprag
New Washers And Bearings
Updated Low Roller Clutch
New Steel Oil Pan
Raybestos Indy Red Clutches
Reprogrammed & Updated Valve Body
Valve Body Spacer Plate
New Internal Wire Harness
New EPC Solenoid
New Shift Solenoids
New Speed Sensor
New 13 Van Pump Rotor
Corvette 2nd Servo
New Selector Shaft
Raybestos Pro Series 2-4 Band
Molded Steel & Rubber
Pure Evil (Level 2 plus the following):
Reprogrammed & Updated Street & Strip Valve Body
Upgraded Beast Sunshell
Maximum Evil (All Level 3 stuff plus the following)
Updated SKF 1 Piece Input Sprag
Raybestos Blue Plate Clutches
Super 2nd Servo
http://www.ls1speed.com/catagory.cfm...y=Transmission
FLP LS1 Level 4 4L60E
Machine pump body and cover to insure true and flat faces
Set pump rotor and slide clearance to .0015-.002 thousandths
High output pump slide spring
Billet aluminum boost valve in pump
Install hardened stator shaft in pump cover
FLP hi-pro friction 2-4 band with solid lining
8-Borg/Warner .078 hi energy frictions with koleen steels 3-4 clutch
Borg/Warner 29 element forward sprag
Borg/Warner 4L65E low roller clutch
FLP heavy duty sun shell with bearing
FLP extreme duty input housing with steel sleeve pressed around input shaft splines with machined overun piston to increase strength
New Borg Warner clutches
New bushings
New GM internal wiring harness
New GM solenoids
New GM pressure manifold switch
New seals, gaskets, and filter
Install Transgo HD-2 performance shift kit with 2 washers
Transgo vacuum mod kit
Corvette servo
Aluminum 1-2 and forward accumulator piston upgrade replaces plastic pistons
Prep case for vacuum fitting and debur case of flashing
Set end play to performance specifications
https://www.flp2win.com/store/produc...0056abe7cfcc87
Bushing Kit
Master Overhaul Kit
New Steel Oil Pan
New EPC Solenoid
New Shift Solenoids
New Speed Sensor
Corvette 2nd Servo
New Selector Shaft
Super 2nd Servo
New bushings
New GM solenoids
Corvette servo
