1-2 shift question
Old Aug 19, 2005 | 06:23 PM
tici's Avatar
Default 1-2 shift question
My 1-2 shift feels harder when I lock the 2nd gear than when I set 4th (or overdrive for the Camaro's).
Shift speed is also different: it shifts at higher speed when I lock the 2nd.
Just a feeling or is it normal?
Thanks - Stefano
Old Aug 21, 2005 | 10:10 AM
Ouija's Avatar
My understanding is that the shifting is supposed to be different if you have the car in the fourth selection option, rather than the third.
(D in a Camaro, or OD in a TransAm, BTW Camaros go 1,2,3,D TA's are 1,2,D,OD)
Old Aug 21, 2005 | 04:38 PM
tici's Avatar
Is this difference something we can adjust? Like Normal Mode vs. Perf Mode?
Old Aug 21, 2005 | 09:55 PM
Ouija's Avatar
In my HPTuners under Edit, Transmission. On the A4 Shift Speed Tab there are four options "Normal, Performance, Cruise, and Hot" for Shift Speed vs. %TPS vs. Shift. For WOT Shift Speed vs. Shift and WOT Shift RPM vs. Shift there are "Normal, Performance, and Hot" So the nutshell answer is "yes I believe youc an modify those options if you have the right software." There are also settings you can tweak for the shifting based on Pressure, Time, Torque, Temp and Gear.
There are also settings for "Normal" and "Performance Mode" in the Torque Management section of HPTuners.
Old Aug 21, 2005 | 10:11 PM
CrabhartLS1's Avatar
Yeah i've definitely noticed my shifts are harder in D than they are in OD. Guess how long i had the car before i noticed that.
Hey Ouija, what's the difference between "performance mode" and "hot" ?
Old Aug 21, 2005 | 10:35 PM
SmokingWS6's Avatar
yes a different table is referenced when you have it pulled down into 2. Mine takes longer to shift and maxes out line pressure, it'll part throttle scratch sometimes.
Old Aug 22, 2005 | 12:58 AM
tici's Avatar
I use LS1 Edit and also see those tables.
But I don't see settings for line pressure or shift speed related on the gear you have selected.
Can you see those tables in HPTuners?
Old Aug 22, 2005 | 01:32 AM
SmokingWS6's Avatar
Some GM v6's have a table called Urban which is only used under those conditions. I assume we have something similar.
Old Aug 22, 2005 | 05:15 AM
tici's Avatar
Can you see it in HPTuners for the V8?
Old Aug 22, 2005 | 05:50 AM
jxaxsxoxn's Avatar
The only thing is the performance mode table is only used in vehicles with a performance or towing button inside. The hot table is for when the transmission is overheating or running hotter than the setting in the transmission diagnostics section. The cruise table only works when the cruise control is on.
So really your only shift table is normal.
