4.10's, a4, and mpg
ya bro.. I agree with scotty, 373s are the way to go.
with 410s you will be looking at 4000+ rpm at 80 mph
I doubt there is much of a heat difference between a 3500 and 4k stall converter, and with a good trans cooler heat buildup isn't much to worry about regardless.
You have 4.10's in the heads/cam car that runs 11.67? Is that the one you are referring to?
no, i have 4.10 in the 00 formula that runs 11.664 @ 117.67. all stock motor from TB to CATS. pulls a disappointing 1.709 60ft. yeah, i liked the 2300 rpms @ 90 mph better than 3000 rpms @ 80 mph. but, my car is more strip action. hers is more street action.
slp airlid
k/n filter
200 n2o motor rating
yank py3400e
4.10 gears
315/35-17 nitto DRs
the wife's car has stock cam just to let you know. her's still has the stock converter and 3.23 gears as well.
You may not find somebody with 4.10's in an A4 that has a before/after mpg on the interstate. Most street cars/daily drivers go with bigger stall and more mild gears. Only time will tell.......
I'm staying with my 2.73s until a 12 bolt becomes affordable. Aslo easier on the 10 bolt.What may help the 4.10+ A4 delimma, is a little thing called Gear Vendors that I first saw featured on Trucks (copperhead has one)
http://www.gearvendors.com/hrgm4s.html
This thing gives you 8 forward gear ratios, including an overdrive for your overdrive
As you can see, the end gear ratio of 4/OD OD on 4.10 gears is 2.24, slightly BELOW the normal 4th/OD with 3.23s @ 2.26. That'll give you back your gas mileage.Only downside, $2k+
