Locking Up the dang Converter!...
I'll keep it simple. When to go get dynoed yesterday and in my dynos i have that huge spike (in the early stage) due to the ST-3500. Lost plenty of RWHP. How do I lock this converter up with Ed Wright Tuning. Can i splice a Wire or tap into something? Im very disappointed with the numbers but its because that Yank is sucking up alot of ponies. i wish i could post the dyno but i dont know how. <img src="images/icons/confused.gif" border="0">
thank you
Do you have a scanned pic of the dyno graph? If so, I'll be glad to host it in my webpage and post it up. Just e-mail it to me. <img src="gr_stretch.gif" border="0"> What were the unlocked/locked #'s?
<strong>It's been a while, but I THINK the wire to tap into on the PCM is tan w/ a black stripe for lockup. I haven't looked at a '98 PCM in close to a year, so you might ask someone else to verify that.
Do you have a scanned pic of the dyno graph? If so, I'll be glad to host it in my webpage and post it up. Just e-mail it to me. <img src="gr_stretch.gif" border="0"> What were the unlocked/locked #'s?</strong><hr></blockquote>
Trevor,
I'll find out for sure what wire it is cuz i dont want to be tapping in to the wrong wire and having the Cars PCM throw a punch at me <img src="gr_grin.gif" border="0"> Trevor, i will try my best to get a scanned pick and have you post it, thanx bud.
My numbers were ( i didn't want to give them out cuz i know that people are gonna get waaay to carried away with it) were:
Unlocked: 341RWHP/380lb. That stupid 'spike' in the begginning of the dyno (due to the converter unlocking i believe) is whats killin me.
okay thanks, heres a full list of mods:
Thunder 224/224 114 cam
FLP's w ORP's through Cutout
Ed Wright Tuning
ASP pulley
SLP air lid
Yank ST-3500
A/F ratio was right on the $$$ with a 12.9
<strong>It definately is pin # 32 ,the tan wire with the black tracer as Trevor said.Tap into that wire,run a wire thru the firewall to one side of a on/off switch.Mount the switch where you can easily reach it during a run.Mine is low on the drivers side of the console.Find a good ground under the dash & run a wire from that ground to the other side of the switch.Mine throws the SES light everytime,but does lock the converter.After it throws the code it won't automatically go into lock-up,you'll need to use the switch until you clear the code.Remember to shut the switch off when you come to a stop in gear,or it will stall.</strong><hr></blockquote>
Aftica
thanks. Now thats pin 32 on the red or blue? You said that it will throw an SES light as soon as you manually lock it up? When will that light come off? I assume you lock up your converter in 3rd gear around 5800 rpms? I just didn't fully understand when you said "you need to use the switch untill you clear the code". Does this mean as soon as you turn the switch off the SES light will go off?
I take it a lock up switch does NOT affect the cars regular occurance of lock up in the city/highway?
thanks
