ordered a 3800 stall with 2.2 str feels like stock
i have a full bolt-on h/c and a 3800 stall with a 2.2 str, did i get sent the wrong stall? because i can move just by removing my foot off the brake, and it drives just like my stock stall. im still on stock gears 2.73's
Try to footbrake stall it. You should at least get it over 2000 rpm before it breaks the rear tires loose. I have a 3500 stall and it drives like the stock converter unless I give it more than 3/4 throttle when I take off. Then it stalls to about 2000 rpm. The most I have gotten it to stall on slicks and the foot brake was 2500 rpm.
I have a 3200 vig, i have to get the rpms up to about 2,000 for normal acceleration, 1500 for slow (people ride my *** when I do that) acceleration, and 2500-3000 for faster than normal acceleration... I would imagine a 3800 being a little more loose than mine
Originally Posted by imslow
lame... i want an 8" verter for a 350/400 that stalls in teh 4,000+ range.
why do you say it came back the same????????? what happened.
i'm going to the track tonight so i'll know for sure.
I would think you would be able to feel a stall like a 3500. I have rev' mine from 2200-2600 to keep up with traffic. If I let off the brake, on level ground, she will creep forward a bit. But with your 2.73s, I should think you may not move little to none at all... My stall doesn' t feel "stock" to me...
Stock stall: http://video.ls1tech.com/Player.aspx...B&t=recent&p=3
Fuddled 3600*: http://video.ls1tech.com/player.aspx...9-5407103A4EB2
Hope that helps ya.
Hope that helps ya.
Hope that helps ya.
Hope that helps ya.
sweet vids, i seen his others but didnt see one of his stock converters. I was laughing like hell cause i watched the stalled one first than i watched the stock vid. Stock one sucks donkey ballz.. Man i cant wait to get my 3,800 fuddle in...
