TH400 Questions
So far it has only had leaks. It works great and smokes the tires into second even shifting at 4500.My question is about manual valve bodies. I hear about full forwards and reverse only and all sorts of terms and I really dont understand what it means. From what I understand it allows you to shift your own gears. How do i know if I have a manual valve body? I dont think i do. I do use my Quarter stick to shift when i want, and I down shift with it because I have no kickdown solenoid. When i leave it in drive (3rd) it starts in first and shifts at 4500rpm to 2nd and 3800 rpm going to third, thus i do the shifting.
I hear this can wear out the trans if it has no manual valve body. True? I have a lifetime warranty anyway so whatever let it break. I also hear that manual valve body setups dont rob as much power as normal setups. What should i know about this stuff? And what is the most efficient setup in case it blows or i feel like upgrading? Let me know what the different valve body setups are.
Thanks and sorry for the long post. I did searches but could not find the info i need.
Lets say i am running voltage to the transmission with the solenoid. Which will have a firmer shift?
The trans shifting automatically?
Or ME putting around with my little quarter stick?
And let me know if its a rumor that a full manual valve body steals less power than a regular setup.
Whats involved in making my trans a full manual valvebody setup, i always shift the trans myself anyway.
Anything else you think i should know tell me. I dont know much about how auto work. The extent of trans work ive done is rebuilding the 2 speed on my brothers revo nitro rc truck.
