4L60E vacuum modulator do you need to adjust it?
I would guess no, because it only controls the line pressure, it does not have as much control over the shift points as a modulator in an older trans does. Am I correct with this?
I'm going to be changing converters so I was in the process of ordering parts to upgrade the trans while it's out.
I got the 3-4 clutches from ProBuilt and seen the vacuum modulator kit.
I think it would be best to do the trans mods and converter, then do the modulator later. Like 50 miles or so later. I don't want to get it together and have a handful of problems not knowing what caused what.
Also going to search a bit more on this.
If anyone wants to add to this post please do.
Plus I always advised people to not use used converters. The converter I have is used but has been cut open and rebuilt, not something I would normally use but I believe the guy I got it from is honest about the history of it and it should be ok. But I'm expecting to have to do some tuning for just the converter change.
The 3-4 clutches and new band should give no problems, it already has a transgo kit but I am going to make some changes to that for the converter, using ProBuilts advice. Enlarging 2nd, 3rd, 4th feeds and the 2nd band release holes. And a beast sun shell.
I can handle the mechanicals but if it starts spitting out trouble codes I'm going to go nuts. I do have HPTuners so that shouldn't even be a problem. I worry too much.
Mec
Sounds easy enough. What does grinding the pin do?
Is this something you can usually install and run or does it typically need to have an initial adjustment after a test run?
The ProBuilt kit says it comes with a pacifier so you get no trouble codes, I'm assuming this plugs into the force motor wiring and provides resistance similiar to the force motor so the computer thinks it's still there, is this correct?
What are the chances I put in a 10" 3000 rpm converter and the vacuum modulator and get no trouble codes?
