Should I take off Torque Management?
Hey you guys. Im about to get a tune for my car since all the mods I want are done. The tuner asked me if I want to take off the torque management on my tranny or not. He said that it is a program GM put on A4 cars so that when it shifts the computer pulls timing and fuel so the there won't be too much stress on the tranny so it will last longer. Some people tells me is a good thing to have, and some people tells me that I don't need it. I was justwondering what are you guys opinion on if I should leave it alone or get rid of it. Any info or expierences are greatly appreciated. Thanks alot.
You're going to get differing opinions here too.
I took all my TM out. I don't see the purpose of modifying your engine to have more power only to have performance taken away from it to save the trans. GM did it to protect the stock trans, you need to upgrade the trans to make it hold up to the increase in power.
I'd get rid of it all, not go down a certain percentage. Modify the transmission to hold the power of the modified engine.
i got all this done to my tranny before i installed the radix to save the tranny as best as i can : all tm is out of this tranny also...
TRANSGO 4L60E HD2 SHIFT KIT
700R4 4L60E BILLET 4TH SUPERIOR SUPER SERVO CORVETTE
700R4 4L60E BILLET SUPERIOR SUPER SERVO
TRANSGO 4L60E SEPARATOR PLATE 96UP TRANSMISSION LS1 LT1
4L60E FORWARD CLUTCH ALUMINUM ACCUMULATOR PISTON 4L65E
4L60E 1-2 ALUMINUM ACCUMULATOR PISTON SMALL PIN 4L65E
SERVO RELEASE CHECK VALVE 700R4 4L60E / CORVETTE ETC
LUBEGARD TH350 TH400 700R4 2004R AOD 727 4L60E 4L80E
its working good so far
You can pull all T.M or adjust the effects. It all depends on driving habits and the amount of power you are pushing.If going for a one time tune i would say, yes.
If you get into tuning you have the option of tailoring the T.M. to your wants.
Hawk .02
Hawk .02
Originally Posted by GREATWALLTA
How big of a difference did it make? And what kind of mods do you have on your tranny?
With the shift kit this would happen more often.
I have the TransGo 4L60E-HD2-B kit with a transgo seperator plate and holes the instructions have you drill drilled at .093, except 3rd and 4th at .106, stock vette type servo with one shim, kit comes with a .500 boost valve, aluminum 2nd accumulator with two washers (too many), pinless fwd accum piston, 3-4 and fwd hi-rev springs, borg warner high energy band and seven 3-4 frictions set to .030.
The car only has a lid and loudmouth exhaust. I'd imagine more mods would hit TM more often.
I got hp tuners and followed someones instructions on how to delete TM and they weren't complete. Run logs were showing a timing dip during shifts so i found all of it and got rid of everything.
Also changed the upshift and downshift points, set it to lock up only in fourth.
Hope all this rambling helps in some way.
I was told that I can also just eliminate some of the TM. Is it a better way to go or is it pointless? How much should I get rid of it if not all of it.
Moderator
TM will still pull spark in an attempt to limit torque.
I prefer to have it in, but on a short leash. I don't
have a big power motor but know that even a "small"
converter is liable to put shaft torque above the GM
rating.
Building a better trans is one option, but not a near
term option for everyone. You can always bust it
later.
Controlling the amount of timing pulled, can make
the car not "lay down". But it might take some
tries before you find a comfortable point where
the torque is mellowed yet acceptable.
Minimizing the shift duration will make any torque
cut less noticeable. Having a total torque cut for
a 0.4-second shift, that sucks. If the shift takes
0.1 sec then you might just miss it. A dead 0.4sec
shift adds an unnecessary 0.3xx sec to your quarter
mile time. But it doesn't need to be that long or
that dead, and then you -can- have it both ways.
On the other hand I tuned on an AWD truck once,
took out the TM and all was good. It would just
blaze all 4 right through the 1-2 shift (blower
truck). Then we got all fancy and put the TM
back in. This let the tires regain traction before
the shift completed and not too many days later
it was time for tranny #3. Bent some sprag or
other, right over. So there's things it'll keep from
happening, but at some point as you mod up the
old Indian joke is still going to not be so funny....
rating.
later.
Torque mgmt. is for people who are scared too hurt their cars.I couldnt believe how much of a difference i felt going from out of box diablo tune (50-75%) to custom tune w/ torque mgmt fully removed. Car blazes the Nitto drs on the 1-2.
My car with a stock motor and bolt ons and a TCI 4000 stall would completely lay on it's face on the 2-3 shift due to torque management and it sucked and really slowed me down at the track. I got rid of it completely and now when I race it the car it shifts like it should. I'm sure I could have played with it and made it work better but I didn't want to.
I have another transmission if this one goes out but it's been fine for a while and all it is is a stock truck 4L60E.
Jimmy blue said it best buy putting it on a short leash. I ran for two years with no Torque Management. Now that I make more power I added some back in to prolong the life of the tranny.
Only Mods to my trans are stall, cooler and tuning. Keeping the transmission cool, getting rid of sloppy shifts(part thorttle and wot) and adding in just the right amount of TM will greatly improve transmission life. My trans now has 50k on it and its holding up quite well to weekly abuse at the track.
Pontiacerator
