Guys w/ tranny coolers please chime in.
I have decided that I want to get a tranny cooler but have no idea what is needed. I tried a search but its not working for me right now. Here are my questions can someone help me out.
1. Is there a specific cooler that works best on the a4 f-bods? If so which one.
2. Where should it be mounted?
3. What can I expect to pay for the install?
Thx
Thx
I just did mine last Wednesday but was in a hurry and didn't get any pics. The way I mounted mine is as follows:
1. Locate the metal line that attaches to the passenger side of the radiator just below the overfill line behind the radiator cap.
2. Get under the car and locate where this line ties into a metal line just under the rack and pinion. This line will be rubber where it ties into the line under the car but changes to metal at the top of the radiator.
3. You will take your fitting and part of your rubber hose that comes with the kit and run it from the top of the radiator with fitting in place and hose connected to the top connection on the cooler. The cooler will be mounted on the passenger side of the AC condenser just in front of the radiator.
4. Run the rest of the hose from the bottom cooler connector to the hard line under the car.
When complete you will have then run the cooler in line where the factory half-metal, half-rubber line used to be.
FYI, You will have a few cuts, if not be bleeding, when you put the zip ties through the cooler and AC condenser because of the radiator fins cutting at your hands.
ive had a trans cooler in mine for a while, but when i had the trans pulled to put the stall in, the guy said it was still pretty hot, how do you guys have it routed?
trans - radiator - cooler - trans
trans - cooler - radiator - trans
trans - cooler - trans
It comes with zip ties that have big flat plates on the end of the tie. You slide the rod end of the tie through the fins and into the separate flat plate you will be holding on the back side. After it is tight, you will have the zip tie holding the two together with the flat plate on the back side of the condenser and one on the front of the cooler.
Originally Posted by Uno99
So the zip ties hold up well?
flare the hard lines. The clamps will want to slide off with out
flaring.
Hawk
ok so the line at the top of the radiator is what you splice or ties into the cooler?
i herd that if you dont put it in the right series then the tranny will burn up is that true and if so whats the correct way?
tranny-rad.-cooler-tranny or
tranny-cooler-rad.-tranny?
