which converter for Street tires
Old Jan 23, 2006 | 09:41 PM
z28pat's Avatar
Default which converter for Street tires
I am currently running 285 40 17 firestone wide ovals,
haven't been to the track on these tires yet,
I am going to be installing a cam (dont' know which one yet)
and am looking for a converter for street tires,
car's got 3.23 gears.
pat
Old Jan 23, 2006 | 09:44 PM
Cheatin' Chad's Avatar
A great all around converter for 3.23 gears is the TCI SSF3500. It is great for street tires IMO. I was able to consistently hook up my 255BFG DRs with this converter and eventually ran a high 10 with it.
Made the car an absolute hoot to drive around town and at the track.
BTW: I ran 12.4 with just the converter,lid and DRs.Then added a 75 and went 11.9. the 150 put me into the mid 11's.
Old Jan 23, 2006 | 11:26 PM
REDWS6ROCKET's Avatar
none, street tires and an aftermarket converter do not belong together!
Old Jan 23, 2006 | 11:39 PM
Scotty-Z's Avatar
Exactly. Even the smallest 2800-3000 converter will still obliterate your tires. To take full advantage of a stall, you need at least some drag radials.
Old Jan 23, 2006 | 11:42 PM
GT Griller's Avatar
If u dont want to get DR's then i would consider a low STR.
Old Jan 24, 2006 | 02:04 AM
Nah, you can temper alot of the unwanted wheelspin with good driving and suspension mods.
Old Jan 24, 2006 | 08:33 AM
s346k's Avatar
converter for street tires: stock
Old Jan 24, 2006 | 08:36 AM
jimmyblue's Avatar
Moderator
I have never been able to hook up even the milder TCI
SF3000/2.2, on Goodyears. I moved to a Fuddle 3500/2.0
and it doesn't hit the tires as hard, is a bit more pedal
controlled in the roll-on but still will lose it on more than
half throttle. A higher STR just makes it that much easier
to smack it right past the limit of adhesion. You have to
educate your right foot, which (oh, no!) will require a lot
of burnout launches until you and your tires come to some
sort of understanding. Try to enjoy the process
Old Jan 24, 2006 | 09:55 AM
Yank's Avatar
Our Super Yank 3500 is made to run a street tire and will give the best launch on the street here is some info on it:
The Super Yank 3500 is a breakthrough in street/strip converters. By using 21st Century materials and CNC manufacturing, the Super Yank provides a superior launch, without blowing the tires off the line. Our customers typically will pull 60' times on drag radials comparable to their competitor's cars on slicks. Although a SuperYank 3500 can easily roast the tires, you can launch nearly as hard on the street as you could at the strip. The SuperYank 3500 provides great midrange torque. The converter will increase torque out to 4500 rpm on an LS1. This eliminates the flat spots after upshifts and makes second gear a monster even at lower speeds. Because of its lower STR and strong midrange, the SuperYank 3500 teams with 3.73s to form a very hot street set-up. As an additional bonus, the Super Yank is the world leader in efficiency...that means your Super Yank will transform engine torque into rear wheel torque almost as efficiently as a manual transmission! All this in a converter that retains good drivability.
Best of all they are on SALE
Old Jan 24, 2006 | 12:19 PM
Scotty-Z's Avatar
Oh, of course by feathering it and taking it easy out of the hole. However, not many people who just want it for on the street and using street tires plan on buying a whole ton of suspension parts (although it would help the most!). I was just speaking for those that plan on hammering it to near the floor as many do.
I learned to curtail much of the wheelspin when I had my 3400, but it was just a matter of not giving it much at all.
Old Jan 24, 2006 | 12:34 PM
Joel_SS's Avatar
I was going to recomend that converter as well.
Old Jan 24, 2006 | 04:18 PM
chrs1313's Avatar
i second that but i would consider getting drag radials or slicks for the track and get an SS line converter
Old Jan 24, 2006 | 06:23 PM
02RedWS6RamAir's Avatar
What do you guys think of the Yank Torque Thruster 3300 for a street car, D/D ?
Old Jan 24, 2006 | 08:20 PM
z28pat's Avatar
Ok,
so the first mod people recommend for an A4 car is the converter, but not with Street tires? I drive back and forth to work 30 miles everyday, I can't do that on DR's.
If I can't do that with the converter, then I might as well just get a cam and 3.73's right?
pat
Old Jan 24, 2006 | 08:30 PM
1jfuddle's Avatar
The main reason that people are talking about drag radials is for WOT runs and flooring it out of the hole. Even then, you can roll onto the throttle and learn to get as much traction as possible. For streetability and daily driving, it can be done, and most people do, on street tires. I do.
Old Jan 24, 2006 | 08:40 PM
z28pat's Avatar
Thanks for the help, it's been harder to decide what to get than it was to save up the money to do it, LOL.
I visited your website and got some good information on it,
what converter would you recommend consider I also want a low/midrange cam with with?
patrick
Old Jan 24, 2006 | 08:43 PM
The Sad's Avatar
Originally Posted by z28pat
Ok,
pat
No, get the converter first. You can drive it with street tires fine. Too much right foot and tires will go up in smoke, you just have to be more careful. Probably no WOT launches.
Old Jan 24, 2006 | 09:53 PM
1jfuddle's Avatar
patrick
Patrick,
I sent a PM. I hope it helps.
Thanks,
John
