What is the lowest 60ft you cut with any size converter???
List what size the stall/str and what your 60ft was, also what tire?? approximate rwhp would be nice...
stock converter...1.87 (street tires)
Soon to come SS3600/2.2....1.6's i hope(definitely slicks )
around 350rwhp
around 350rwhp
best street car 60's ive seen are about 1.3, and im sure its a full suspension, slicks, 9" and a 5000rpm+ race stall...
me personally, im going to get a 3600rpm/2.2str stall from fuddle when i get some extra money (wife is sucking me dry) and some et streets, lookinf for a 1.6 60', but best to date is 2.0 on the shittiest tires you can think 60 dollar honda/walmart tires on a stock stall...good luck
Bolt-ons
1.9 stock converter. - stock 17" Goodyear F1's, 3.23's
1.69-1.7's TCI 3500. - 17" Nitto Dragradials, 3.23's
1.62-1.65's TCI 3800. - 17" Nitto Dragradials, 3.73's
1.48-1.53's TCI 4400. - 26" ET Drags, 3.73's
Cam Only
1.48- 1.51 TCI 4400. - 26" ET Drags. 3.73's
1.45-1.47 Yank 4800. - 28" ET Drags. 4.30's
Cam Only
1.58-1.59, some 1.60's- Fuddle Racing 4000 2.5
stock motor w/ headers-ORY 330rwhp, stock suspension, stock 16's up from 275/50/15 MT DR's out back, stock 3.23's, 3700lbs
Alot of your 60ft. depends on your cars weight and what tires you have up front. I have a bolt on car with 17x9's on the front and 17 bfg's on the back, vig 3200 and it cuts 1.67-1.69's The car weighs 3440 WO driver. With skinnies it would do alot better.
1.43 60ft with TCI 3800 2.5str, 3.73 gear, 5000da, 3900 race weight, 27x11.5x15 on weld xp's, approx 550 rwhp, spohn torque arm, tubular lca's, and a moser 12 bolt with a -2 degree pinion angle. Car would do consistent 1.4-1.5's.
boltons/fuddle 3400 2.1/3.73s nitto 275/40/17 full weight 1.79
same as above but with 26x10.5x16 et street bias ply 1.73
same as above with 100 dry shot 1.61
all with c5 17x8.5 and toyo 275/40/17, spohn LCA's and panhard bar
