Guys running th400
Old Feb 1, 2006 | 10:19 AM
Anniversary "Z"'s Avatar
Default Guys running th400
Any of you running a converter that was not custom built for an LS1? I'm planning on doing this and need to know where I can get an adapter to act as a spacer between the converter and flexplate or some ideas what you guys used to keep the converter snug against the tranny.
Thanks
Old Feb 1, 2006 | 04:22 PM
z28convert's Avatar
i just bought a b&m th400 and used a 6.0 crank spacer. with a tci flexplate.
Old Feb 1, 2006 | 11:15 PM
SUX2BU's Avatar
i'm not running a spacer.
Old Feb 2, 2006 | 09:29 AM
That's a lot of help one of you is and one of you isn't Anybody else?
Z28convert - where did you get your crank spacer?
Old Feb 2, 2006 | 04:17 PM
z28convert's Avatar
from a local gm dealer. i cant remember what i paid exactly but it is more than i had expected. for a "spacer" i was expecting less than 15 bucks but i think it was over 50.
Old Feb 2, 2006 | 08:33 PM
SUX2BU's Avatar
some people say its dangerous to run without one so i would suggest you get one or have a longer "nose" welded on to your converter.
Old Feb 2, 2006 | 08:34 PM
SUX2BU's Avatar
oh and instead of trying to explain a "th400 in an LS1" just tell them your running a 3/8" rear motor plate and need the converter "nose" extended 3/8".
Old Feb 6, 2006 | 09:12 AM
Who would be able to extend the nose of a converter? I'm assuming you can't just take it to any welding shop since balancing and what not is a must.
Old Feb 7, 2006 | 12:45 AM
Jimmy P's Avatar
TCi makes them like that, and I believe so does Yank. I ordered one from Fuddle and I will how I like it when it comes in and get it installed.
Old Feb 7, 2006 | 10:34 AM
Well I already have the converter it's just not setup for an LS1 it was actually intended for a BBC but never got installed. I'm starting to think that crank spacer may be the way to go. What all does the installation of that require? And it's just a "6.0 Crank Spacer"?
Old Feb 7, 2006 | 11:33 PM
SUX2BU's Avatar
just take it to any converter shop. or tranny shop that deals with race trannies.
