?'s about changing converter lock up mph.
Opinions please...
Jim
Are you sure it is a shudder and not cam surge? You don't experience the shudder under moderate acceleration in that same speed range? does the same problem happen if you let the converter lock-up in 3rd gear?
Cam surge can be cured through tuning w/o changing lock-up. you might experiment with 3rd gear. you may find lock-up in 3rd works fine at 40 mph but you want 4th gear set to 50 mph.
FWIW, I didn't have that problem with the thunder cam on my car and lock-up would stay engaged on coast down to about 35 mph.
Thanks.
Jim
What is your idle speed at? Do you have your IAC count down around 30 when the motor is fully warm at idle? Have you tried opening the TB just a tiny bit more by turning the TB set screw about 1 full rotation?
Jim
Thanks.
Jim
Look for a hot (go out and put some miles on the car and then measure) IAC count around 20 - 40 in gear at a stop. If you are above 50 I would adjust the TB to open it it a bit (1 turn) and let more air in.
Jim
Jim
Later.
Jim
Later
Jim
Jim
Suggestions? Anybody?
Jim <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Lubeguard make a product for "deglazing" the clutch, but I haven't used it yet.
Here's my very uneducated answer...
Untill you get computer tuning the computer pulls line pressure as the lock up clutch engages.. this cause the lock up clutch to slip.
