Thanks Fuddle!
That's the same converter I'm gonna get! Hope it works well for you. I sure hope they don't send me PMS though.....I get enough of that at home.
You are definitely going to be needing some DR's or ET streets.
"TM" .. torque management, I assume?? What does one need to do, exactly, with thier TM when they install an stall converter?
I recently bought an 02 WS6 with a 3200 Yank converter in it .. but the guy never mentioned anything about having done anything with the TM.
now this doesnt happen to everyone, but ive heard of it happening more than not, if you put a stall in and leave the TM alone, the computer will see the stall as the trans slipping, and i guess it tries to correct for it, end result is the trans kills itself
i have the TM deleted, and havent had any problems, i even had the TM gone before i had the stall put in, no problems then too
