Race prepped 4L60E. Which one to get?
Leo
They say the 3 is good to about 400hp and the 4 to around 500hp.
My plan is to get the 4 within the next few weeks so I guess I shall see.
Ozz
For people around here have you heard of "Michael's All Transmissions" it is by hobby airport.
Works PERFECTLY.
He does the VM kit and some proprietary stuff just like chuck at FLP along with better clutches,steels,pump kit and better sprag.So far its holding up VERY WELL on 1.47 60ft's.
And I didnt py 2200 for it <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
U need to contact CARTEK if u want one f these boxes.
JS
<small>[ April 08, 2002, 10:52 PM: Message edited by: JS ]</small>
It's got about 12,000 street / strip miles on it (about 75 passes, most 1.5 60fts <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> )
I believe the street stuff is much worst on these things than anything.
My trans was redone in 2000 by FLP. It worked great. The plan was always to bring it back after a year and open it up for a inspection. I got a few hundred bux off when I first bought it, but it was not free or anything.
Now, when the car was up at ARE for the 422ci upgrade, they pulled the drivetrain out and went thru the tranny. I had no tranny problems, but I subsequently did. Not to bore you folks to tears, but the converter got damaged during the reinstall and damaged the tranny.
I had FLP redo the tranny late last fall.
I have 30 dyno pulls on it.
I have been only driving on ET Streets Since October.
Car has 60 fted a best of 1.51 and many mid 1.5's.
I am a very abusive driver.
I have had the car up to 150mph a few times.
I have about 50 passes on this one.
I highly reccomend the FLP tranny because it does work.
I always monitor heat. I think that's why mine lasts.
The PCM does in fact shift my tranny, even though I have the vacuum modulator. You cannot shift any pcm-governed tranny sooner than the programmed shift points at WOT. But you can wind out the shifts and manually shift but it's hit or miss.
Let's all compare notes when we all have 100 passes on our transmissions.
My first FLP build had in fact about 300 passes on it.
I know that Chuck incorporated some new ideas in my tranny when it was redone back in early October. I retained the billet servo from ARE even though Chuck warned that I would not like the hard downshifts when slowing for stoplights. Chuck and I also argued about Kevlar vs OEM bands and never agreed to a agree. But then again I go with his design, because from what I have seen many aftermarket trannies only hold up for like 20-30 passes.
Another trick with mine, is that I never get on it until I am at operating temp.
I also will let 2nd wind out manually during cold start driving, kind of like how the truck's wind out 2nd gear when cold (pcm program).
I also have a THREE rule. I will never do more than three passes in a row. The heat start out at 185F with my car and goes up to 225F by the 3rd pass. Everything I have read says that 250F+ is the kill zone for trannies.
Problem area for our trannies is the 3-4 clutches.
<small>[ April 09, 2002, 10:58 AM: Message edited by: Pro Stock John ]</small>
Thanks,
-Jim
<small>[ April 09, 2002, 10:38 PM: Message edited by: key master ]</small>
Again, let's see how all the aftermarket trannies do after 100 runs or so.
I need to correct my post, I have FLP's first LS1 4L60E.
Keep in mind that a rebuilt HP tranny is more than just slapping in new parts. Chuck at FLP has spent a lot of time looking at tolerances and problem areas for these trannies.
A 1994 Z28 that he did about three years ago has gone three years without tranny problems even when the car was being sprayed with a 200 shot. That 94Z was not on slicks but was abused quite a bit.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That was beatiful. I think I`m gonna cry.... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Tim
