stall question
Old Apr 10, 2006 | 08:01 PM
silver30th's Avatar
Default stall question
thinking about picking up a stall, not sure though....what would be best for a daily driven, 3.73 rear end car?
Old Apr 10, 2006 | 08:54 PM
BNKBRKR's Avatar
I've got a 3400 stall in my '02 SS with 3.23 gears with a 224 cam and it is just about perfect (actually see about 2600 w/foot brake, and 3100 if I flash it). It makes a hell of a difference from the stoplights! But you will probably need to get some drag radials because with street tires and those 3.73s you'll probably send them up unless you slowly roll into it.
Old Apr 10, 2006 | 09:05 PM
mvonada's Avatar
Talk to some of the sponsors on this site and they can give you all the info you need.
Old Apr 10, 2006 | 09:47 PM
98SS Blackattack's Avatar
For the ls1 cars a 3500stall is a DD converter. For the LT1 im not sure.
Old Apr 10, 2006 | 09:50 PM
camaro4ever's Avatar
Default off subject question
hwo did you come about getting those gears for your car? i have been searching for someone that carries that gear ratio and i am having no luck
thanks
Old Apr 10, 2006 | 10:00 PM
thanks
The sponsers
http://www.thunderracing.com/catalog...&vid=3&pcid=67
Old Apr 11, 2006 | 02:31 AM
BlackHawk T/A's Avatar
For your LT1, probably somewhere in the 2800-3200 range.
Old Apr 11, 2006 | 07:08 PM
silver30th's Avatar
thanks
many gear companies do, such as motive, and where i got mine from, strange.
thanks for all the advice
Old Apr 12, 2006 | 05:32 PM
01_ram-air's Avatar
Be a man.....Go 4000!!
Old Apr 13, 2006 | 12:58 AM
On a near stock LT1?
Old Apr 13, 2006 | 08:44 PM
1BADTALS1's Avatar
not to thred jack but i got a question
i know what the w/footbrake is but what does it mean to "flash" it
Old Apr 14, 2006 | 12:56 AM
Floor the pedal from idle. Flash is the RPM it will jump to before you move. It will be near impossible to tell with the stock tach.
