probs with fuddle 3600 2.2 converter
get it to my tranny guy to install it.....he puts the converter in and cranks the car...makes a ton of racket....sounds like converter bolts are loose but they are TIGHT....flexplate is ok and tight and straight (tci flexplate btw)....plenty of fluid....
so we unbolt the converter and press it away from the flexplate a lil....turn the motor over...sounds fine...bolt it back up and makes racket....
converter spins like a top when installed on the tranny....with no noise or interference....
we bolt the converter back up and turn the motor over with a ratchet....sounds fine...no noises or hang ups....
i have 150% confidence with my tranny guy...hes fully built my 4l60e with no problems and has done a lotta work for me and its top notch....i doubt its installation error.....
any thoughts/suggestions/comments???
i called jason at fuddle and left a message...
dave
I sent you an email and left you a voicemail. I hope I can help get this figured out. Let me know what I can do.
new track times will come....see how it compares to my 4000 im taking out...
