p0571
Old May 25, 2006 | 02:07 PM
vMaster0fPuppets's Avatar
Default p0751
Im throwing a code saying shift selanoid A is is stuck off or something about performance. I'm also having a problem with my converter unloicking on itself in 4th gear every once and a while. What does, this mean? Could they be related? WHat should I do?
Old May 25, 2006 | 09:05 PM
BubaGumpShrimp's Avatar
did you just put a converter in, if so what stall
Old May 26, 2006 | 02:43 PM
Ive had a stall for a couple months now. Its a fuddle 3400.
Old May 26, 2006 | 07:48 PM
The people at Autozone said there might be something actually stuck in a seloniod. How would I be able to tell without ripping the thing apart.
Old May 26, 2006 | 08:13 PM
2001NBMZ28's Avatar
Don't think the code is correct - Probabaly P0751? Doublecheck if that's what AZ told you. I'd do a search in this forum for both P0751 and P0757.
Old May 27, 2006 | 01:42 AM
actually it is p0751, must have mistyped it. What can this mean?
Old May 27, 2006 | 02:18 AM
Cody Brooks's Avatar
if its a performance code then it is valve problem or problem in the hydraulic circuit. since you have a stall it may just be a false code due to the computer not knowing that it is dealing with a tc that isn't stock.
Old May 28, 2006 | 12:26 PM
I have a problem with my converter unlocking itself at cruising speeds occasionally, could this be a factor?
Old May 28, 2006 | 12:51 PM
computer probably commanding the convertor off and on as a safe-gard. to know for sure one would have to take a test drive and watch the solenoid command status on the scan tool to see what the computer is commanding versus what is accually happening.
